Previous in Forum: What CNC is Best Fit to Produce This Product?   Next in Forum: Tube to Tube Sheet Fabrication
Aluminium Extrusion
01/26/2013 11:44 PM
i am not succeess in extrusion of solid round bar of boron/aluminim,
i use regular shape die or conical both die i use for,
but the surface finish is not ok it very ruf finish,
material is AL3B (Aluminium 97% + Boron 2.5 to 3%)
extrusion speed is 5 to 9 mm
temp is 400 to 420 degree celcius
billet size 85mm
road size 45mm
container length 17 Inch
Die which i use is one conical type the other is bearing type 5 & 25 mm
tempture and pressure is ok but i request u pls any
one have idea about the die shape so i request to suggest me
-------pankaj
Re: Aluminium extrusion
01/27/2013 12:26 AM
What are the specific characteristics of the "ruf" finish? What is your maintenance procedure for the die's? What are you using as a lubricant or are you not using any? Have you tried lower speed? A closeup pic of the problem would be useful....
01/27/2013 12:50 AM
thanks...ok after half hour i post some picture
01/28/2013 10:40 PM
02/16/2013 8:56 AM
Polish ur extrusion die ,heat the aluminum to a higher temp and run it thru a size calibrator while cooling
Register to Reply 4 comments
mtdmaker (1); pankajp (2); SolarEagle (1)
