Previous in Forum: How to Dry Wet Polypropylene Plastic Power   Next in Forum: Fasinating Tour of the ISS
22 comments
An Exploratory Research Mechanism
01/27/2013 3:38 AM
Range of Motion Video (profile)....
http://www.youtube.com/watch?v=P_vF3ooVwAU
Range of Motion Video (front)....
http://www.youtube.com/watch?feature...&v=E7CEwnOFnCk
I've been working on this (hobby status) on and off over the last fifteen years or so.... a mechanism that immediately begins to rotate in either direction with an imbalancing displacement of as little as one degree. With repeated periodic displacements of as little as five to seven degrees its rate of rotation rapidly approaches about a 100 to a 150 rotations per minute over the course of just eight to ten repetitions, all while overcoming only negligible frictional resistance from the main axel (equipped with bearings). It may have some applications for extracting rotational motion more efficiently from wind and wave and maybe a couple of other things too.... or it may just be a work of art.
A uniquely balanced mechanical arrangement, its motion is pendulous.... but unlike a simple pendulum which has two possible positions of equilibrium (stable when down and un-stable when up), this Pendulum, because of the way it's balanced, actually has four possible positions of equilibrium.... two un-stable positions alligned with the force of gravity (up or down vertically).... and two stable positions perpendicular to the force of gravity (positioned to either side horizontally).
Gravity isn't being switched or turned on and off, the influence that gravity has on the Mechanism is being changed by changing its condition. I'm getting the Mechanism to rotate by periodically changing its condition. The Control Lever at the rear (connected to the Calibrated Spring) is the part that's periodically moved back and forth (3 to 5 degrees approx.) and is fixed to the Main Axel (white) and Sun Sprocket (gold with white center) of the Planetary Chain and Sprocket arrangement. The Planet Sprocket (black, with the Pendulum that is fixed to it) is affected through the imbalancing action of the Sun Sprocket, transmitted to it by the Chain.
It swings to one side, and then, by changing the condition of the Mechanism at the appropriate time, the Pendulum continues its swinging motion (taking an eliptical path) to the other side without losing kinetic energy gained. I believe that's why it begins to rotate so quickly and forcefully.
It's a pendulous Mechanism that rotates relatively forcefully at the first introduction of a relatively slight imbalancing force. The input force needed to imbalance the Mechanism, delivered to the system via the Control Lever, is sensibly comparable in every way to standing a pencil on end, holding it at the top and moving it back and forth an inch or so, which is exactly what I feel during testing like that shown in the videos.... almost nothing.
The actual driving force needed to cause rotation of the Mechanism as a whole can't be imparted to the Planet Sprocket by the Sun Sprocket via the Chain because the Sun Sprocket doesn't move in such a way as to impart rotational motion to the Planet Sprocket which leaves gravity as the only other driving force available to explain why it immediately begins to rotate in response to a slight imbalancing force.
In all the diagrams the length of a line represents the magnitude of a force and the arrow itself represents the direction of a force, so no mass is explicitly stated anywhere in the analysis . For example....
The situation graphically depicted in the diagram below won't change as long as any arbitrarily stated magnitude of force for the vector D is uniformly applied as a standard. In other words.... Whether one arbitrarily states for the vector D a magnitude of force equal to two ounces or sixteen pounds the resulting diagramatically shown vector proportions won't change in any way, and the diagram will remain an accurate representation for both scenarios (two ounces or sixteen pounds). So, since any arbitrarily stated magnitude of force for the vector D will result in an identical diagram and identical vector proportions, for the purpose of analysis, there's no need to state any specific magnitude of force for the vector D in the diagram.
Any arbitrarily stated magnitude of force for the vector D (or any other vector in the diagrams) uniformly applied as a standard gives the magnitude of force associated with any of the other vectors in the scale drawings of the analysis. For example....
If the vector D is made to equal one inch and the arbitrarily stated magnitude of force associated with it is two ounces (one inch equals two ounces), then....
A.... 3/8 inch equals 0.75 ounces
B.... 3/4 inch equals 1.50 ounces
C.... 3/4 inch equals 1.50 ounces
D.... 1 inch equals 2.0 ounces
E.... 3/8 inch equals 0.75 ounces
F.... F = C + B.... 0 ounces
If, instead, the vector D is made to equal one inch and the arbitrarily stated magnitude of force associated with it is sixteen pounds (one inch equals sixteen pounds), then....
A.... 3/8 inch equals 6 pounds
B.... 3/4 inch equals 12 pounds
C.... 3/4 inch equals 12 pounds
D.... 1 inch equals 16 pounds
E.... 3/8 inch equals 6 pounds
F.... F = C + B.... 0 pounds
For the purpose of analysis the very same numerically un-adorned diagram serves to describe both of the above scenarios equally well.
The diagram (below) illustrates both the direction and magnitude of the forces arising from the various moving parts of the mechanism individually and shows (FIG. 4) how they ultimately cancel each other out.
FIG. 1 - Schematic representation of the Chassis.
FIG. 2 - The Chassis is fixed in this schematic. The diagram shows the downward force A of the Pendulum and the resulting force B on the Planet Sprocket.
FIG. 3 - The Sun Sprocket is fixed in this schematic. The Chassis and the Planet Sprocket are free to rotate. The diagram shows the downward force D of the planet sprocket. The force C on the Planet Sprocket is the result of the force D after the force E from the oppositely situated Counter Weight (fixed to the chassis) is subtracted, or.... D minus E equals C.
FIG. 4 - The Sun Sprocket is fixed in this schematic. The Planet Sprocket with its attached Pendulum and the Chassis are free to rotate. The equal and opposite forces B and C acting on the Planet Sprocket effectively cancel each other out, or.... B plus C equals F.
A series of schematic diagrams (below) show how the equal and opposite forces B and C cancel each other out at various points around 360 degrees (the sun sprocket is fixed for this part of the analysis), presented here as an animation....
In order to render the mechanism purturbable the sun sprocket must be free to move. When it's free to move the mechanism's equilbrium (which was stable at all points around 360 degrees when the sun sprocket was fixed) can be purturbed via the chain by a slight change in the position of the sun sprocket by means of the control lever, which is fixed to the same axle as the sun sprocket. This is also the condition in which four distinct positions of equlibrium emerge. I found a video of an older model (balanced the very same way as the current model) that clearly demonstrates the four possible positions of equilibrium that arise when the sun sprocked is freed to rotate (two stable and two un-stable), appearing in the same order as listed below the video. The video also shows how the mechanism can be caused to rotate as easily in one directon as the other....
http://www.youtube.com/watch?v=OoF3zUu8G9s]Images
1. Pendulum horizontal to the left, stable equilibrium.... the mechanism can't be caused to rotate by the action of the control lever from this position.
2. Pendulum horizontal to the right, stable equilibrium.... the mechanism can't be caused to rotate by the action of the control lever from this position.
3. Pendulum down vertically, un-stable equilibrium.... the mechanism can be caused to rotate by the action of the control lever from this position.
4. Pendulum up vertically, un-stable equilibrium.... the mechanism can be caused to rotate by the action of the control lever from this position.
This constitutes a perturbable form of balance that can result in immediate onset of rotation (in either direction), presented here as an animation....
A problem then arises as a direct result of the sun sprocket being freed to rotate for the purpose of perturbing the mechanism's equilibrium via the chain. The varying forces arising from changing mass distribution during rotation that were formerly transmitted directly to the stand when the sun sprocket was fixed now come to bear on the control lever instead. The diagram (below) shows the downward force D on the Planet Sprocket. The force H on the Sun Sprocket is the result of the force D, and the force I on the Control Lever is the result of the force H. The Mechanism is not balanced or in equilibrium in this diagram because there is no equal and opposite force to counter the force I.
That's where the calibrated spring comes in.... it's mounted on the back of the Mechanism (depicted to the right in the diagram below). The lower end X is fixed to the stand the mechanism is mounted on. The upper end Y is connected to the Control Lever. The diagram (below) shows how the equal and opposite forces I and J effectively cancel each other out and equilibrious balance Q is the result, or.... I plus J equals Q. The Mechanism is in a state of compensated equilibrium, the sum of all forces acting on the control lever is zero.
I want to minimize the magnitude of the input force needed to perturb the system.... the calibrated spring variably compensates for and cancels out the varying force coming to bear on the control lever due to changing mass distribution. The sum of the equal and opposite forces I and J coming to bear on the control lever equals zero at all times during rotation as shown (below). This constitutes a compensatory form of balance. It reduces the input force needed to cause immediate onset of rotation to the level of that needed to overcome only frictional resistance from the Main Axel (equipped with bearings), presented here as an animation....
Timing.... the stage of the analysis that illustrates the variable timing function of the adjustable Cam and Standing Lever. The diagram below shows the Cam that's located directly behind the Sun Sprocket. It's fixed to the Chassis and rotates with it. The Standing Lever (visible in the videos as a second lever moving back and forth in front of the Control Lever) and the corresponding position of the Cam that's moving it are depicted to the left.
The Planet Sprocket with its attached Pendulum, the Chassis and the Sun Sprocket are all free to rotate in the following schematic diagrams, presented as an animation....
By linking the Standing Lever to the Control Lever the mechanism's position can be synchronized with the position of the Control Lever at all points around 360 degrees.... analysis is on going.
Re: An Exploratory Research Mechanism
01/27/2013 9:35 AM
What is the purpose of such a contraption?
01/27/2013 3:54 PM
Proving that all-caps isn't the only way of shouting; boldface also works.
Good Answers: 445
01/27/2013 9:44 AM
Perpetual motion/over-unity alert!
01/27/2013 7:44 PM
lyn "What is the purpose of such a contraption?"
I think I covered that in the title "An Exploratory Research (http://en.wikipedia.org/wiki/Exploratory_research) Mechanism" and in the first paragraph too, where I wrote "It may have some applications for extracting rotational motion more efficiently from wind and wave and maybe a couple of other things too.... or it may just be a work of art."
Tornado "Proving that all-caps isn't the only way of shouting; boldface also works."
That doesn't doesn't prove anything at all.... except maybe that you're either very easily distracted or just don't know how to stay on topic. Boldface isn't shouting, using all-caps and bright colors is. I'm not using all-caps or bright colors so if you don't like it don't read it.
RAMconsult "Perpetual motion/over-unity alert!"
No, it's AN EXPLORATORY RESEARCH MECHANISM ALERT!!!! That's shouting Tornado.... can you hear me now?
And now, here's my first impression of this forum (in the form of a pictorial comment) and the responses up to this point.... I'll leave it to you guys to figure out who's who....
Thanks for all the warm (if useless off topic/irrelevant one liner) welcomes.... Emile
01/27/2013 7:52 PM
I see now. It's a solution looking for a problem.
01/27/2013 8:51 PM
lyn "I see now. It's a solution looking for a problem."
No lyn, it's not a solution looking for a problem, it's "a type of research conducted for a problem that has not been clearly defined. Exploratory research helps determine the best research design, data collection method and selection of subjects. It should draw definitive conclusions only with extreme caution. Given its fundamental nature, exploratory research often concludes that a perceived problem does not actually exist." Do I need to shout it?
01/27/2013 9:11 PM
No shouting necessary.
You have proven me exquisitely correct by your own definition.
It's a solution to a "perceived problem that does not actually exist".
Trudge onward, I'd be happy to follow you on your quest.
01/27/2013 9:14 PM
Has joe.fordham adopted a new pseudonym?
01/27/2013 9:23 PM
Nah. Joe didn't have moving drawings and real models. All he had was mouth.
I can see a cool clock here, at least. Not much more.
01/28/2013 1:23 AM
lyn "No shouting necessary."
We'll see.
lyn "You have proven me exquisitely correct by your own definition."
No, so far all you've proven is that you're exquisitely dense. I never provided any definition of "Exploratory Research", Wikipedia did.
lyn "It's a solution to a "perceived problem that does not actually exist".
Well, that really just confirms my initial impression of you as exquistely dense. What the Wikipedia entry ACTUALLY SAID (yeah Tornado.... that's shouting) was that "Given its fundamental nature, exploratory research often concludes that a perceived problem does not actually exist.... it doesn't say anything about exploratory research looking exclusively into problems that do not actually exist. Have another cup of coffee if you think it'll help.... I'm doubtful it will.
lyn "Trudge onward, I'd be happy to follow you on your quest."
See what I mean? I NEVER (oops....there I go shouting again Tornado, can you ever forgive me?) said I was on any kind of quest. At least at this point, I wouldn't bet a nickel on what, if anything, any of you are capable of "following".... Confidence is not high.
Tornado "Has joe.fordham adopted a new pseudonym?"
joe.fordham? Who the hell is joe.fordham? Tornado.... is this all leading up to some kind of intelligent contribution? Is this your idea of a logical/analytical debate? If so.... condolences to your parents.
lyn "Nah. Joe didn't have moving drawings and real models. All he had was mouth."
Yeah, right.... kind of like you guys.
lyn "I can see a cool clock here, at least. Not much more."
If you really knew how clocks worked you couldn't/wouldn't have written that. Along with the rest here tells me you're all either just a bunch of phony mechanical engineers at best, or at worst, just a bunch of internet fakes.
So.... which is it? Phony or fake?
Good Answers: 183
01/28/2013 8:00 AM
Not worth a dime to continue the discussion. I should recommend to close the thread since the only argument is the insult
If we do not shout ossana to the genius we are fakes. Disgusting reaction.
01/28/2013 8:25 AM
Please attach any name you like. Phony or fake will work.
Dense is fine.
Ignorant won't hurt my feelings, coming from you.
You exhibit the classic signs of false intellectual superiority and the inability to accept criticism, constructive, or otherwise.
Why are you wasting your time here with a bunch of dense people who are too stupid to grasp your brilliant idea?
Surly you can find an audience that will praise your genius, somewhere.
Good luck.
01/28/2013 12:52 PM
Looks like a political engine to me.
01/28/2013 1:16 PM
nick name "Not worth a dime to continue the discussion."
I agree. To have a discussion there would have to be at least one intelligent on topic question or observation wouldn't there? Since the only remarks made were a couple of ridiculous little quips about perpetual motion and boldface print being shouting I don't see that it'll ever get that far.
nick name "I should recommend to close the thread since the only argument is the insult"
Who cares. You might have turned it around by asking an on topic question or making some kind of observation but instead, your post is just another off topic remark added to the rest.
nick name "If we do not shout ossana to the genius we are fakes."
It's not about shouting ossana to the genius or you're a fake, it's about asking an on topic question or making some kind of relevant observation/on topic remark. I didn't set the tone for this exchange.
nick name "Disgusting reaction."
A disgusting reception gets a disgusted reaction.... no mystery there.
lyn "Please attach any name you like. Phony or fake will work.
Dense is fine."
Good.
lyn "Ignorant won't hurt my feelings, coming from you."
And meaningless off topic little one liners from you guys won't hurt my feelings either.
lyn "You exhibit the classic signs of false intellectual superiority and the inability to accept criticism, constructive, or otherwise."
That's baloney.... What's that opinion based on? Where is anything like that indicated? No one has given any criticism, constructive or otherwise, that could be accepted or rejected. So, where is the criticism, constructive or otherwise? Where in any of the opening remarks is there anything that would support your saying that? That's right, there isn't any, which makes your observation about my exhibiting "classic signs of false intellectual superiority" a bunch of nonsense.
lyn "Why are you wasting your time here with a bunch of dense people who are too stupid to grasp your brilliant idea?"
I never said it was a brilliant idea (do you enjoy just making stuff up?). All I said was that it's an exploratory research mechanism.
lyn "Surly you can find an audience that will praise your genius, somewhere.
Good luck."
Yeah right.... good luck to you too.
01/28/2013 1:30 PM
<subscribe>
01/28/2013 2:34 PM
…….I don't see that it'll ever get that far.
This post is not going far because you have personally attacked every responder.
Although I understand this device is a Research Mechanism, I too would ask, what practical application could it possibly serve?
A question asked by other posters, a valid question, not warranting personal attacks.
It would seem the power output of this will allow it to do nothing more then sit on a desk as a conversation piece.
Good Answers: 183
01/29/2013 7:20 AM
Dear Sir,
I wanted to make it short but your sick mind deserves a better comment.
We have at CR4 in a quite regular repetition the "pleasure" to have such sick persons as you are.
In general a theme can be or not be of interest, some time comments are pretty rough but only a few react as you do. You theme is not interesting that is all. Instead of understanding it you started to insult people because they do not appreciate your research. This can happen to the most intelligent people, history shows that many times ideas were not accepted when they did appear but a lot later.
A person of your type but in good health would have understood and reacted accordingly, you did not thus I consider that you should go on your own to consult a psychological or psychiatric expert and take some medicine.
If your state of mind keeps an evolution in same direction it could be possible that you will be brought by other to the consulting room and this is much more painful.
May I wish you good health and a positive evolution.
My reaction is not due to you personal attack but generated by a feeling of sorrow with respect to your state of mind.
01/28/2013 2:20 PM
Congratulation, you seem to have succeeded at perturbing the system...
01/28/2013 2:34 PM
Hey, why are you not off topic?......... I see the possibility of some type of record here, so don't blow it.
01/28/2013 2:36 PM
My bad, sorry.
01/28/2013 2:37 PM
We are all off topic because there is no topic.
01/28/2013 3:27 PM
Yes, and I would like to see 100 off topic responses please.
But isn't being pointless a point in it's self?
Register to Reply 22 comments
Aemilius (4); Anonymous Poster (2); JPool (2); lyn (6); nick name (2); phoenix911 (3); RAMConsult (1); Tornado (2)
