Previous in Forum: Ball Mill Trunion Bearing Oil Seal   Next in Forum: Differece between ASME Sec VIII and IS:2825
Accelerometer Working Principle in Inverted Flight?
01/31/2013 8:03 AM
How the accelerometer gives the negative acceleration (-1g)value when it is in inverted flight?
Re: accelerometer working principle in inverted flight?
01/31/2013 8:23 AM
Many hand-held telephones have the ability to determine which way is up these days. How about a telephone call to the telephone equipment manufacturer to find out, perhaps?
Good Answers: 92
01/31/2013 9:36 AM
Especially when you drop them!
Good Answers: 92
01/31/2013 9:38 AM
↑ Sorry, forgot to post OT ! One more thing Savvy needs to change for editing.
Good Answers: 183
01/31/2013 8:23 AM
An accelerometer measures in general a force thus when the force is <0 it means it has an output negative and this means that the vector has the other direction (opposite) to the one for which the signal is >0.
Re: Accelerometer Working Principle in Inverted Flight?
01/31/2013 1:50 PM
I just got this mental picture this is being posted by a Boeing maintenance engineer for some reason.
Good Answers: 88
01/31/2013 4:45 PM
With a negative (below zero) value if output is analog or with Two's complement if output is digital. S.M.
Good Answers: 21
02/03/2013 3:30 AM
Aircraft "G" meters are made to feel the + & - forces. If you were to take a unit apart you would see that the meters movements are bi directional. Hence +/- readings. The newer electronic units work in a similar fashion sensing the movement of a weighted unit on an electrical slide if you will relating to positive voltage and to negative voltages (thats a very simple explanation).
I forgot to add that inverted is the only way to fly! Straight and level is not much fun anymore. Give me a good snap roll with a newbie any time.
Register to Reply 7 comments
fixitorelse (1); jack of all trades (1); JNB (2); nick name (1); PWSlack (1); SimpleMind (1)
