Previous in Forum: Fabric Edge Finishing -Heat Sealing   Next in Forum: Atmosferic Plasma to Treat Polypropylene
Coolant Recycle System
02/02/2013 9:15 PM
Is there any standard for coolant recycle system? I mean the coolant after going through a recycle system, is there a standard to measure the cleaniliness of the coolant? Thank you.
Re: Coolant recycle system
02/02/2013 9:26 PM
02/02/2013 10:04 PM
It only shows your product.
So what are the standard to measure? Before and After.
02/03/2013 9:06 AM
It's not my product. It is an example of a supplier of filtration systems.
There's contact information there. So, contact the manufacturer of this equipment and ask them what standard they use.
02/02/2013 10:29 PM
Liquid Nitrogen is pretty much the standard coolant we use. It is also very easy to recycle.
02/02/2013 10:32 PM
Liquid Sodium doesn't need to be recycled. If any leaks out to atmosphere there will be a big problem.
02/02/2013 10:41 PM
Sorry, I am referring to metal machining coolant. Thanks
Good Answers: 21
02/04/2013 12:54 AM
filter to 5 micron and you should be good unless your picking up something other then machine chip waste. At 5 micron you will not damage pumps or valving.
fixitorelse (1); hmgoh (2); lyn (2); redfred (2)
