Previous in Forum: Earthing Between Pump and Motor   Next in Forum: Current Flowing Through Parallel Connected Conductors
Specification During Design
02/03/2013 4:28 AM
I want to undergo my feasibility study on designing 220/132KV RING CIRCUIT SUBSTATION, What are the recommanded specifications on selecting proper four Transformer (T/F) which will fit for interconnection btn two substation circuit 2.For Generating Units and 2 for Power Transformation.What I know some like
T/F SIZE RATINGS
33/132KV sub. 12-15MVA
66KV/11KV sub 40MVA
132KV sub (NR) 40MVA
220KV sub (NR) 60MVA
66/132KV sub ?????
220/132KV sub ??????
66/33KV sub ?????/
220/66KV sub ?????
220/33KV sub ??
For Higher voltage ????
NB:It is necessary to note, NR =NO RING CIRCUIT and sub=substation .These ring ciruit CONNECTION, the opposite transformation is true but hopefuly we will have the same MVA ratings.Lastly some studies were done based upon already installed capacity but justification or commandment is also acceptable.
Good Answers: 181
Re: Specification During Design
02/03/2013 6:49 PM
02/04/2013 4:44 AM
This is a detailed design job based upon local information and constraints. If a local qualified HV designer is not available at present, then it is time to hire that individual.
The role involves removing all those question marks.
Register to Reply 2 comments
