Previous in Forum: Refrigerator   Next in Forum: Remote Controller for Laptop
9 comments
IGBT Vs PWM
02/05/2013 11:07 AM
Why IGBT technology is superior to PWM used in Power Factor Correction, UPS etc.?
Re: IGBT Vs PWM
02/05/2013 11:19 AM
Is it because the abbreviation has four letters, and the others have three?
Anonymous Poster #2
Re: IGBT Vs PWM
02/05/2013 11:20 AM
Dunno. Why don't you tell us?
Re: IGBT Vs PWM
02/05/2013 11:46 AM
IGBT=insulated gate bipolar transistor
PWM=pulse-width modulation
UPS=United Parcel Service
I just can't trust anything that is bi-polar, so I ship everything UPS.
Re: IGBT Vs PWM
02/05/2013 12:12 PM
Your question is same as: A turbo engine is more superior than a car. IGBT is A better semiconductor switching device used in PF correction or UPS, because it is cheaper on same voltage and current handling basis and driving circuit is simpler.
Sharing knowledge is one thing that defies basic arithmetic logic --- the more you share, the more you get!
Re: IGBT Vs PWM
02/05/2013 12:16 PM
I think you'll find it's not either/or BUT both.
Re: IGBT Vs PWM
02/05/2013 12:29 PM
I know the advantages of IBGT Vs SCR when performing PWM in charging the BAT of a UPS. The output of the UPS can utilize FIR when using an IGBT instead of a SCR to minimize the THD waveform. The THD of both input and outputs can then controlled to adjust the PFC. I also can quickly tell an ESO condition just from the collection of acronyms used.
Re: IGBT Vs PWM
02/05/2013 1:45 PM
Too many TLAs.
Re: IGBT Vs PWM
02/06/2013 2:14 PM
Ones hardware, the other is a technique (it is not an apples-to-apples comparison).
IBGT use over other technologies such as mechanical switches or transistors however results in IGBTs being better (better reliability over mechanical switches, lower losses over transistors, etc).
Try a wikipedia search of IGBT and PWM for more information.
Good Answers: 82
Re: IGBT Vs PWM
02/08/2013 9:00 AM
Hmm, I'm guessing the relevant terms you're looking for are IGBT, BJT, MOSFET and then PWM, the idea being that the first three are different types of fast electronic switches used to create Pulse-Width Modulation, and IGBTs are preferred.
BJT, or bipolar transistors, were the original fast switching parts used to create PWM, 40 to 50 years ago. Switching frequencies were generally 50kHz or less. Then in the early 80s BJTs were supplanted by the superior properties of power MOSFETs, or Metal-Oxide Semiconductor Field-Effect-Transistors. Shortly after, IGBTs, or Insulated-Gate Bipolar Transistors came along (schematic symbol at left). These combined the best properties of BJTs (low switch saturation voltage) and MOSFETs (zero-DC-current gate drive). At high voltages MOSFETs suffer from a high RON (it rises by as much as the square of the breakdown voltage rating). For voltage ratings above about 300 volts IGBTs have a lower switch saturation voltage at high currents than does a MOSFET of the same die size. That's the key word, die size. A 1200-volt 20A IBGT costs less than a similarly-rated MOSFET, which is a big deal.
Furthermore, if you run these two parts for a short time at say 40A, the IGBT's voltage drop will be far superior to the MOSFET's voltage drop. In fact the IGBT's power dissipation rises roughly proportional to the current, while the MOSFET's rises power dissipation rises proportionally to the square of current. What's more, the switches in high-power applications generally run hot, and IGBTs have are much less affected by high temperatures than MOSFETs. That's because of a nice BJT property, VCE(sat) is independent of temperature. The plot is from International Rectifier's app note AN-983, page 5. Ouch, that makes the MOSFET look really bad. The IPP60R099 in the plot is a 0.1-ohm 650-volt MOSFET priced at $5.60 at Mouser (qty 100), whereas the IRGP4063 is a 600-volt IGBT with VCE(on) = 1.65V, rated at 48A, priced at $5.37 at Mouser, TO-247 case shown at left.
Notice how the MOSFET was rated with a resistance, but the IGBT was rated with a fixed voltage drop.
[We should add, the MOSFET still has its place over the IGBT, e.g., the IPP60 can switch 400V at 18A in just 5ns, whereas the IRGP4063 takes 45ns for 400V at 48A (and it's called an ultrafast part). Faster switching speeds make a big difference in some applications, but generally not in low-frequency high-voltage off-line switching.]
So this answers the question, Why IGBTs vs MOSFETs for PWM. And the general-wisdom stock-answer answer is, they are better for high-power use at voltages above 300 to 500 volts. They're cheaper and they have lower power loss at high currents.
Thanks, Win
Anonymous Poster (1); bravo88 (1); jack of all trades (1); lyn (1); PWSlack (2); Randall (1); redfred (1); Winfield Hill (1)
