Previous in Forum: Dynamic Braking Resistor   Next in Forum: CPS (continues power system )
9 comments
Hobbies - Automotive Performance - New Member Hobbies - CNC - New Member
Quick Question About Wire Connection
02/06/2013 11:49 AM
Hello,
I was trying to connect one main electrical wire into 4 cartridge heaters in parallel. I am going to the hardware store to buy supplies i need for this, and I wanted to know what is the best way to do this. Is there a clean way to do this rather than use terminal strips which would be exposed, any special connectors that I do not know of??
It is better to fail in originality than to succeed in imitation.
Re: Quick Question About Wire Connection
02/06/2013 12:04 PM
Heaters need periodic replacement, so I'd keep it simple.
Ideal High Temperature Wire Nut® Wire Connectors, Wire Nuts
Don't know how important looks and tidiness are to you, but this is what we used on our injection molders and thermoformers.
02/06/2013 12:38 PM
I would use a bus connector, or as a last resort a split-bolt....
Good Answers: 804
02/06/2013 1:17 PM
The bronze split bolts in that photo are likely the only things you will find at a hardware store.
02/06/2013 1:37 PM
You can get ceramic terminal blocks if the connections are going to be exposed (remember standard plastic terminal blocks will likely deform and melt due to the heat).
If the connections can be covered to prevent finger access then uninsulated crimp connections could be an option.
Safety first, always.
Additionally this is all assuming the heater cartridges are bare rather than already fitted with a cord. If your heaters do have cords then fit plugs to the ends and use a 4-way outlet board for safety (assuming your wall outlet can handle the current). This allows a safer connection that can be easily connected and disconnected.
Again safety first.
02/06/2013 2:21 PM
What are the wire gauges of the various items to be connected?
02/06/2013 2:38 PM
What wattage???
Good Answers: 266
02/06/2013 3:07 PM
High temperature terminal strip. Ceramic body. Terminals pretty much touch safe recessed into the body of the ceramics. Rated for 1000º F. Cost for of 4 terminal strip like $3.00 US McMaster Carr.
In that the info is not given as to how far out of the heat the connections will be. If far enough set a junction box and use wire nuts. I've used cartridge heaters that had 36 inch leads that ran thru a harness into a panel. Where they were terminated right on the SCR controlling them.
02/06/2013 10:40 PM
You may use a metallic junction box (JB) with ceramic terminal blocks inside the JB.
02/07/2013 10:37 AM
Can't believe nobody suggested this :
Register to Reply 9 comments
debata07 (1); jack of all trades (1); JPool (1); JRaef (1); lyn (1); ozzb (1); SolarEagle (2); Tornado (1)
