Previous in Forum: Seal Welding After U Stamped   Next in Forum: WPS Range
Opening Nozzle on the Seam Welding
02/10/2013 1:35 AM
I am doing fabrication for rectangular tank (ATM pressure), I have two nozzles 12'', I try to avoid to open the nozzle on the seam welding but no way, there is any problem to open the nozzle on the seam welding?
Re: Opening Nozzle on the seam welding
02/10/2013 8:58 AM
Dear Mr.Abusaleem,
I have faced a similar situation and we got an advise to do as follows:
1. Cut open a circle (where you want to fix the nozzle) in the tank, and the Dia. of hole should be 1.4 D where D is the Nozzle dia. In your case it is 12" nozzle and hence 16.8" say 17 inches to be cut.
2. Take a plate of 1.5 t, (where t is the thickness of your vessel) and cut a hole suitable for your Nozzle OD, and Weld the Nozzle to this plate and weld this plate to the tank.
Pl. try for this and post the information how you did this job in this thread or through CR4 PERSONAL MESSAGING.
DHAYANANDHAN.S
02/18/2013 12:22 PM
Dear Mr DHAYANANDHAN.S Thanks for your reply, and sorry for late response due to problem on my PC, As I understand from API 650 for openings, all nozzles above 2'' we have to make nozzle pad equal to 2D, could we open for the nozzle only 12" and weld 24" pad ?
02/20/2013 10:29 AM
02/22/2013 9:41 AM
Register to Reply 4 comments
