Previous in Forum: How to make manufacture metal fillers   Next in Forum: Carbon, carbon and carbon.
Ion specific sensors
05/26/2007 5:50 PM
I see that ion specific sensors are V expensive.
Anyone got any whacky ideas or theories for a cheap way to sense Cu2+ ions in water (at low concentrations)?
This is a work related query, so don't give away your IP !
I Just wondered if there are any theories I could play with...My discipline is electronics and mechanics rather then chemistry ... but I'll have a dabble with anything.
Del the (curious) Cat
Pathfinder Tags: ion specific sensors
Re: Ion specific sensors
05/26/2007 9:03 PM
Hi Del,
How low?
While you're answering, I'll see what I can come up with.
Mike
05/27/2007 4:02 AM
Ta,
I'll get back to you on that when I'm back at work...Tuesday.
05/29/2007 7:25 AM
Hi,
Back at work today.
We are looking to measure values upto about 1ppm. (expected range 0.4 - 0.8 ppm)
United States - Member - USA Engineering Fields - Control Engineering - Never enough money
05/27/2007 5:40 PM
Here is some thing I found after a quick search.
I tend to measure copper in the low mg/l and µg/l ranges so color-metric measurement such as the Hach pocket kit is the best method for my application. I would love to install a APA 6000 Low Range Copper Analyzer to reduce chemical exposure to the techs that pull hourly samples but even with a 30% corporate discount the bean counters don't want to spend the money.
05/27/2007 11:51 PM
I don't have much of a background in anything related but since copper is such a good conductor it seems like the impedance of the solution would be somewhat inversely proportional to it's concentration. I'm sure that's probably wrong but it's the only thing I came up with.
05/28/2007 4:02 AM
Thanks for the response, but I already use a conductivity sensor (2 stainless steel pins with a short 5v pulse to sense conductivity) but too many other chemicals effect this sensor.
Dunno if just having different metal for the electrodes woould help...or different pulse time?
Register to Reply 6 comments
Anonymous Poster (1); Mikerho (1); Richard L (1); user-deleted-1105 (3)
