need to find supplier of individual scale turn key , solar power systems , for water pumping and for lighting systems , and be available on a bulk rate type demand...Does anyone have any ideas, if so please contact me at ; email removed - CR4 Admin.
Your best chance is to do a Google search. There must be thousands of companies out there that can give you what you want. We don't even know what part of the world you're from.
Best of luck
John
Best advice I can give as you get older "Never miss an opportunity to relieve yourself"
I think it is very difficult for jesw55 or any one else to know that you are a 'veteran US citizen' and not an 'idiot foreigner'. By the way, I couldn't understand why did you put the particular adjective before the word ' foreigner'? I think in such a forum you should restrict your discussion to technical matters only, rather than writing some emotional comments.
As per you all foreigners are supposed to be Idiots, which includes Europeans, Asians, Africans, Australians, etc.?
Shame I thought that Apartheid only was in South Africa
Google your request and be prepared to spend some time finding the right size and type of items that will suit your needs.ps I'm also a vet but over here we dot not seem to share that info.best of luck
To Carve a lion from a block of stone just chop away the part thats not the lion
Contact these folks, http://johnsonmellohsolutions.com/. They are based in Indianapolis, but I don't know how far they travel. They have significant experience in PV systems and are well respected as a contractor.
"We have met the enemy, and he is us." -- Walt Kelly
