Previous in Forum: Nose Level, Control Valve   Next in Forum: Seeing Tank Side Monitor Data on NXA820
Interface Level Transmitter
02/15/2013 1:06 PM
Dear Sir, can send Remote seal interface level transmitter calculation steps for oil water saperator Please.
Thanking You.
Re: interface level transmitter
02/15/2013 1:39 PM
Step 1. Contact the manufacturer of the instrument.
Step 2. Follow instructions given in step #1.
Mind readers we are not.
Re: Interface Level Transmitter
02/15/2013 3:32 PM
I'll go ahead and take a shot in the dark. Something like this?
More details would result in better answers
The first law of thermodynamics is you do NOT talk about thermodynamics.
02/18/2013 9:47 AM
Jibipaul,
Your question is difficult to answer because you do not give any information as to the interface of what liquid and what other one, what are the chemical, physical and thermodynamic properties, and furthermore you want some one to do your work for you.
The formula to measure interface level is the differential pressure of the hydrostatic column compensated for the density of the products.
This generally works if your level is between liquids which have at least 0.35 between their densities, they do not foam and have clear interfaces, otherwise you may need to analyze the issue differently.
Register to Reply 3 comments
lyn (1); Mizuti (1); vargaalex (1)
