Previous in Forum: Simple Sensor Design for Armatures   Next in Forum: Interface Level Transmitter
Nose Level, Control Valve
02/14/2013 12:02 AM
Dear All,
What is the maximum noise limit for Control Valve in a two phase Service
Regards
Jose
Re: Nose Level, Control Valve
02/15/2013 10:13 AM
If I understand what you are asking, that is always a specification we get from the end user. They will state the entire system must be under xxdB. So, it depends on what the end user wants to limit it to. Don't know of any mandated noise limits other than occupational exposure rules, such as OSHA's 85 dB/8hr, which do not actually limit the noise generated by the valve as long as the people in the vicinity have appropriate protection.
01/15/2014 10:56 AM
Hi,
There are no methods/Model available in IEC for the practical calculation/prediction of Noise in a Two phase control valve.
So the only thing you can do is to ask the vendor to confirm if the noise level generated is below 85dBA.
Vendor will confirm based on their experience of similar application. That is the reason why you will not find Noise level mentioned in the fisher Calculation sheet (or in FSM output) for two phase control valves.
Register to Reply 2 comments
