Previous in Forum: Square D SyMax Model 650 PLC System   Next in Forum: Cold Temperatures, Condensation, and Electronics
11 comments
Connecting a Transistor 2N3055 with Heat Sink
02/17/2013 4:54 AM
Is the heat sink of this unit to be insulated/isolated from the metal body of the unit to
which i intend to install it, since i understand that the positive of this transistor is the collector and is the body of the transistor?
Re: connecting a transistor 2N3055 with heat sink
02/17/2013 7:42 AM
That all depends on the rest of the circuitry. One certainly can use this transistor in a circuit that has only a negative supply and attach this collector to a chassis connected to ground. Typically the collector of this transistor would be electrically isolated from the chassis, as you propose. Now one can have an electrically isolated from ground heatsink in direct contact with this transistor case to improve thermal transfer from case to heatsink. Even in this case a thin thermal compound paste should be applied between heatsink and case that will fill tiny voids between surfaces.
02/17/2013 1:38 PM
Well I wouldn't ground the 2N3055 case as it is the collector.
You don't need to isolate the case (collector) if you can ensure that the heatsink won't accidentally be shorted or come into contact with anything else. We would advise isolation however as general practice dictates.
Good Answers: 38
Re: Connecting a Transistor 2N3055 with Heat Sink
02/17/2013 9:34 PM
Good Answers: 42
02/18/2013 1:15 AM
There used to be a "rubber" insulator that did not require any grease. I was more familiar with a mica insulator plus thermal compound, and Teflon shoulder washers that were inserted from the back side of the heat sink for the mounting bolts.
That socket he is using is pretty slick.
02/18/2013 9:54 AM
There are still companies that make rubber like insulating pads. Bergquist's Sil-Pad is one such product. The video has a common misconception about thermal grease. As the transistor case heats up the case will warp. The rate of heat transfer from transistor to heat sink is dependent on the contact surface area between solids. A warped transistor case will have less thermal conduction to the heat sink. Thermal grease or a thick flexible insulator will fill the voids between solids as they warp.
02/18/2013 9:19 PM
Fully agree with GW....
Last I remember working with this transistor, we ALWAYS had mica to isolate the body, and plastic to isolate the legs/pins.....
'Course I've been away from college and TVs for xxx years........
02/18/2013 12:00 PM
http://www.youtube.com/watch?v=mPGusBmm3XE
P-N thermal . . . basics re-visited
ci139
Good Answers: 58
02/18/2013 9:52 AM
The case of your TO-3 package is the collector of the transistor. If this is always at the same potential as your case or mounting surface, you don't need to isolate it electrically but you should still provide a low thermal resistance path to the case. This is normally done with thermally conductive grease that you can get at any electronic supply store. If you require electrical isolation, you can obtain a kit with a mica or thermally conductive gasket to electrically isolate the transistor from your chassis. You should still use the thermally conductive grease.
02/18/2013 11:07 AM
ci139
02/18/2013 11:29 AM
http://www.ieeta.pt/~alex/docs/applicationnotes/dc%20power%20supply%20handbook.pdf
(nidnightfind muhaha - a quck P-sup how to / how not to - Hi, my name is Justin Case)
ci139
Good Answers: 12
02/18/2013 10:31 PM
If in debate...
ISOLATE
It depends on the circuit and the physical topology of the circuit.
Bill
Register to Reply 11 comments
ci139 (3); Epke (1); GW (1); jack of all trades (1); redfred (2); Sciesis2 (1); Sid_Sidow (1); welderman (1)
