Previous in Forum: Application & Type of CDG Relay For Protection From O/c & E/F.   Next in Forum: Golf Cart Battery Problem
9 comments
LED as a DC Bulbs
02/19/2013 9:52 AM
How can I used LED as a 12 V. DC Bulb
Re: LED AS A DC BULBS
02/19/2013 9:56 AM
Just feed it 500mA DC power at 2.5-3.5 volts.
02/19/2013 10:11 AM
Good Answers: 69
02/19/2013 10:22 AM
Use a series resistor, calculate it using this formula:
R= (V supply - V LED)/LED current
If your led has a forward voltage of 3.6 V, your power supply is 12 V and the nominal current of the LED is 500mA (which is fairly high, found only on modern high light output LEDs), then it should be:
R= (12-3.6)/0.500 = 16.8 ohms
You can use a broad range of voltages and resistor values, only make sure you don't exced the nominal LED current.
Good Answers: 73
Re: Led as a DC Bulbs
02/19/2013 12:03 PM
It really depends on which LED you select. The average LED only uses 20 mA not the half amp that was suggested previously.
There are several suppliers who provide LED replacement bulbs for existing sockets. Sometimes, however, the bulb is too big to fit the fixture.
02/19/2013 12:23 PM
The least efficient but simplest method is to just provide a series resistance to handle the voltage drop from 12V to the diode voltage at the desired current. One of the most efficient approaches would be to design a switch mode power supply that outputs a constant current into the LED. A SMPS can be designed to handle a wide input voltage range so a failing 12V battery will produce the amount of light. With circuit miniaturization a SMPS can be incorporated into the base of many light bulbs.
Re: LED as a DC Bulbs
02/20/2013 12:53 AM
Use LM 317T and make a constant current source of the desired mA.
Gajanan Phadte
12/10/2020 2:35 AM
Just buy one.
Good Answers: 804
12/11/2020 4:29 PM
7 years later, I think it is no longer an issue for the OP...
12/10/2020 4:53 AM
For a single LED you need a 330 Ohm 1/2 watt resistor in the circuit...
For 3 LEDs in parallel you need 100 Ohm 1 watt resistor...
For 3 LED's in series....47 Ohms 1/4 watt...
...Or you can just use a current limiter...
https://lighthouseleds.com/20ma-led-current-limiter-driver.html?gclid=CjwKCAiAq8f-BRBtEiwAGr3DgSh9G17sIL2G_OzliSZf6Benm1nv2sjmeq4FlSfs_fkI7-WApOn9KhoCeFkQAvD_BwE
Register to Reply 9 comments
gmphadte (1); JRaef (1); lyn (1); NotUrOrdinaryJoe (1); PWSlack (1); redfred (1); SolarEagle (2); Yahlasit (1)
