Previous in Forum: Camcorder as a cam to VoIP   Next in Forum: Thermocouples
scada data base
05/27/2007 3:35 PM
hello all
i have a scada system done by SIEMENS PLC step7 300 and my SCADA was programmed by WINCC flexible2005 advanced.
my problem is the following :
i want to build a data base using access or excel to record, display and print variables' values of my system
important for me
thank u
hany
United States - Member - USA Engineering Fields - Control Engineering - Never enough money
Re: scada data base
05/27/2007 6:19 PM
Re: scada data base
05/28/2007 5:30 AM
The SCADA data is stored in a CSV (comma separated variable) file, which can be imported into Excel by declaring the starting cell & automatic fill either down or across (check settings).
Madness is all in the mind
Good Answers: 204
Re: scada data base
05/28/2007 10:28 AM
I'm currently spending a fair bit of time working with excel and vba, so maybe in my spare time (lol) I could help you out. chrisg288@hotmail.com
I also have done data projects with control systems before when I worked for Johnson Controls. If the data is csv, then I wouldn't need to know much about the software you are using.
Chris
Register to Reply 3 comments
chrisg288 (1); GM1964 (1); Richard L (1)
