Previous in Forum: LCD Replacement   Next in Forum: PLCs in Mexico
ODTR Test
02/26/2013 1:24 AM
Dear All
I have carry out ODTR test for my optic cable at home about 20M length both splice with Fusion splicing.
my concern is after the OTDR and print out the report i am getting this value ???
below is the detail of the report result.
Feature #/type 1/N 2/E?
Location (km) 0.0912 0.1855
Event(dB) ?? ??
Event (dB-km) ?? ??out of range
Loss(dB) ???.??(2P)
Any advise.
Regard
Moh'd
Re: ODTR Test
02/26/2013 10:19 AM
ODTR or OTDR? You use both in your post. Presuming you mean OTDR (Optical Time Domain Reflectometer), check the specs on the instrument. You are most likely testing a cable that is too short for that model. 20 meters probably falls within the "blanking pulse" area, which is why you are seeing the "out of range" results.
Re: ODTR Test
02/28/2013 9:45 AM
Dear All
For the OTDR testing of F.O cable what is the minimum length of cable to be test.
REgard
Moh'd (Kuwait)
Re: ODTR Test
02/28/2013 10:02 AM
Well according to this article: http://en.wikipedia.org/wiki/Optical_time-domain_reflectometer , anywhere from 0.15 meters to 15 kilometers. It depends upon the accuracy of the OTDR meter. That is why I wrote "check the specs for that instrument".
I can't Read The Frickin' Manual from here; so you are going to have to do it yourself.
