Previous in Forum: Hydro Dual Dump Bed   Next in Forum: Cut Car Crashes with a Sawsall
Car Problem
02/27/2013 11:46 AM
what could be the problem with my car engine premio 1998 D4 engine,ith has the following problem
1. lacks power during accelaration
2.has code 12 which has failed to clear even after replacing crank sensor
recently i purchased obd code scanner.but it could not link with the ECM,what could be the possible DTC connector type since the pins layout are 4,6,7,9,13,14,16...is it OBD compliant really?
Pathfinder Tags: car problem
Re: Car Problem
02/27/2013 12:15 PM
Sounds like the timing is retarded.
Re: Car Problem
02/27/2013 12:18 PM
Your car is too old .
Re: Car Problem
02/27/2013 12:21 PM
Good Answers: 50
Re: Car Problem
02/27/2013 1:55 PM
How many miles or Km on the engine since overhaul?
Have you done a compression test? Does this meet manufactures specification?
Engine runs, but may be very worn out. Is it burning oil?
ignator
ignator -
Re: Car Problem
02/28/2013 12:08 AM
The most probable reason is that the timing is not being advanced. Newer cars, since about 1980 or so no longer have a vacuum advance on the distributor. It is computer controlled, hence the code. A good mechanic can tell you if that is true. If you are going to be Mr. fixit, then find a Chilton's auto manual for your car. The answers are in the Chilton's. I believe it is a problem with your automatic advance of the distributor.
A hand without an arm is a useless tool
Re: Car Problem
02/28/2013 3:41 PM
Does this have an OCV (Oil Control Valve)? I think Toyota's have trouble with them. Does a complete oil change help anything? And you also might want to look for a manifold leak.
I'm not a mechanic... Just speaking from some experience.
Re: Car Problem
02/28/2013 10:26 PM
Register to Reply 7 comments
129CBRider (1); Anonymous Poster (1); Byron Jay (1); ignator (1); lyn (1); PWSlack (1); snatr (1)
