Previous in Forum: Chilled Water   Next in Forum: Interpret the Specs
Bucket of Komatsu PC4000-6
03/02/2013 8:07 PM
HI
I'M MARTIN
WHAT'S THE BEST STEEL FOR A BUCKET OF KOMATSU PC4000-6 AND WHAT KIND OF WELDING CAN I USE FOR WEAR PLATES.
THANKS FOR YOUR ANSWER
Re: bucket of Komatsu PC4000-6
03/02/2013 10:33 PM
Last May you were at the same place:
JUAN MARTIN ASATO KOBASIGAWA
STUDENT OF MECHANIC ENGIENIERING
ENGIENIERING UNIVERSITY
LIMA PERU
I'd check the commercial section, over there.
You'll need hard steel and a good welder.
03/02/2013 11:15 PM
thanks for your answer
now, i´m working for Barrick gold in Peru
and i have to develop a solution for wear plates because it´s replaced every 7 days
well i´m thinking in A-514 and A-572 steel, weld: welding with Manganese
thanks
03/04/2013 3:35 AM
No joy with the phone call to Komatsu, then?
Re: Bucket of Komatsu PC4000-6
03/04/2013 12:29 AM
Manganese steel has very good wearing resistance and it is being used in Earth moving equipments industry, Welding electrode shall have atleast equal or slightly more chemical composition that of a manganese steel.
03/04/2013 5:05 AM
The following will give some insight to material selection
1. Impact resistance.
Used manganese steel, of which most impact-resistant parts are made. Examples: Earthmover bucket teeth, crusher parts.Stainless steel electrodes are often used. Deposited metal is tough, not necessarily hard.
2. Abrasion resistance.
a. Examples: Cultivator sweeps, plowshares, scraper tools.b. Tungsten carbide and chromium carbide electrodes are commonly used.c. Deposited metal is very hard and resistant to abrasion.
3. Resistance to corrosion and abrasion at high temperatures.
a. Cobalt-based or nickel-based electrodes.
4. Resistance to severe abrasion with moderate impact.
a. Cobalt-based or nickel-based electrodes are used.
5. Resistance to abrasion with moderate to heavy impact.
a. Iron-based alloy electrodes are used.
Anonymous Poster (1); jasatok (1); lyn (1); PWSlack (1); Savvyquest (1)
