Previous in Forum: Omron LY2 12 VDC 8 Pin Relay Wiring?   Next in Forum: Why Line Matching Units Are Used in Only Two Phases?
12 comments
What Does 2 * 1500/1 A Current Transformer Mean?
03/03/2013 10:21 PM
I am working in 400kv Switchyard.Here all current transformers are mentioned as 2*1500/1 A rather than 3000/1 A. Now I would like to know why this kind of nomenclature is used.
Experience is what you got by not having it when you need it
Pathfinder Tags: ct Current Transformer
Re: What does 2 * 1500/1 A Current transformer mean?
03/03/2013 10:33 PM
Re: What Does 2 * 1500/1 A Current Transformer Mean?
03/04/2013 2:13 PM
Apart from the obvious answer (it's just two 1500/1A current transformers), are you saying you have a current transformer that is marked 2*1500/1A but is actually for a 3000A primary current?
03/11/2013 10:26 AM
It is connected to a bus of 3000A
03/11/2013 12:36 PM
By the way, 400kV x 3000A x √3 = 2,076 MVA switchward (2 GVA) is this correct?
Good Answers: 804
03/04/2013 2:17 PM
If I saw that on a one-line diagram, I would interpret it simply as 1500:1 CTs on 2 phases.
03/04/2013 11:06 PM
What is the rated current of the circuit -1500 or 300A. If 1500A it might mean 2nos CT 1500/5A one for measurement another for protection,if it is single line diagram.
pnaban
03/11/2013 10:30 AM
No, For measurement, different class of CT are used
03/05/2013 3:54 AM
It means that you can make connection (parallel or serial connection) for all current transformers and choose ratio 1500 or 3000 A / 1A .
Good luck
Location: ROUEN (in NORMANDY), 120 km from Paris, France, Europe, Earth, Sun Sytem, Milky Way, Universe.
03/05/2013 3:59 AM
Hello,
That means you have a C.T. with a double primary winding. If you connect them in parallel you have the double primary current (in your case: 3000 A). This is because your installation has been increased in current, and all switchyard had to be increased in a same way. It is common at conception of a switchyard when it has not been well defined what will be the nominal current, carried by the O.H.Lines. The conception had certainly defined that nominal current would increased at the most five years after starting of the switchyard. And also due to the big price of the 400 kV C.T.'s and their not possible replacement.
Hello, BRZK
That's all, Folks. Take some time to learn where you live...
03/05/2013 8:18 AM
You meant Double secondary winding !
03/11/2013 4:30 AM
No , he thinks double primary winding and the possibility of connection in series or in parallel .
Good luck
03/11/2013 10:33 AM
Thanks a lot for each and every one of you, for taking trouble in answering questions.
Register to Reply 12 comments
brzk (1); dreamchaser (3); jack of all trades (1); JRaef (1); LAA_Lucke (2); lyn (1); Panta SD (2); pnaban (1)
