Previous in Forum: 24/7 tracking device for child/old persons   Next in Forum: Cassette Tape Chassis
Mobile Phone Hanging
03/03/2013 11:54 PM
Hi all
I have purchaced a mobile phone "Samsung Advance", about three months back. Since then I am facing a problem that the phone is getting hanged. If anyone of you know the reason please help me to solve this problem,
Thanks n Regards
Re: General discussion
03/04/2013 3:31 AM
Simple. Take the phone back to the supplier and demand a warranty replacement.
03/04/2013 5:29 AM
Do you wear your tin foil hat while using the phone?????
If yes; that's the problem.
If no; follow advice previously given by PWSlack. Tell them your phone is dropping calls.
Re: Mobile Phone Hanging
03/04/2013 11:47 AM
Perhaps a reset might fix it. Make sure you connect your phone to your computer and backup anything you can like contacts, pictures, videos, music, etc. A reset will probably delete all these, but may fix the problem. I quick search for "Samsung Advance factory reset" yielded this result:
http://www.telusmobility.com/en/AB/Samsung-A885-Advance/how-to-000489.shtml
CAUTION: Resetting your smartphone deletes your ringtones, contacts, pictures, messages, and other downloaded content. If you want to save this content, use third-party software.
  1. Tap Menu.
  2. Tap Settings.
  3. Select Phone.
  4. Select Reset Phone.
  5. Tap Yes.
  6. Enter the password. This is typically the last 4 digits of your phone number (unless you've changed it).
  7. Tap OK.
Your phone is reset to the original factory settings.
lyn (1); PWSlack (1); yamdankee (1)
