We were facing seious insulation damages with the MV induction motors without any evidence because the previously measurement shown normal in term of values, polarization index and absorption. The failure always took place at starting moment of two 500 and 1500 HP MV motors, the workshop cheking chown winding fault to ground. After all we arrived at the conclusion that problem was originated by a voltage peak coming from the chopping current caused by the fast action of the vacuum breaking contact swiching which develop a voltage transient and hence the motor insulation failure.
On top of this, the motors are placed in subtropical environment where the humidity increase upto 90-95 % by late afternoon following sunset, the temperature reduce and the humidity remain high inside the total enclosed motor.
The solution found was, upgrading the voltage suppressor system in the motor feeding and vacuun contactors and rise up the anticondensation heaters rating
Just waiting for your comments
Bye
