Previous in Forum: Vacuum Contactor Peak Current And Motors Insulation Damages   Next in Forum: Protection of Earthing Grid from Corrosion
Record
03/12/2013 1:23 AM
How will keep a Portable applicance record (PAT)
Re: Record
03/12/2013 4:05 AM
In the same way as any other: PencilAndPaper 1.0 is good enough.
Re: Record
03/12/2013 5:08 AM
I'd keep it in the pocket, but one might want to use a proper briefcase for it!
Re: Record
03/12/2013 5:27 AM
There's a lovely piece of software called RingBinder 1.0. Sits on a bookshelf. Needs no USB connection and will run anywhere without connecting to the mains. Highly recommended.
Re: Record
03/12/2013 7:48 AM
You can also get that in a portable app, called stenoPAD.
Re: Record
03/12/2013 10:26 AM
Wow. That's good news.
Anonymous Poster #2
Re: Record
03/12/2013 4:40 AM
Why don't you tell us?
Re: Record
03/12/2013 3:11 PM
Hello again?.
Some PAT testers record the values allowing you to download them to a computer or even print them out in a report directly from a printer built in to the PAT tester (check the manual for more details).
It really doesn't sound like you are qualified to operate a PAT tester at all (refer to local electrical testing standards and codes for more details including who is allowed to operate a PAT tester).
Are you aware that you and your manager or supervisor are legally responsible if someone checks or if something goes wrong and you are not qualified to perform said testing work? Fines, jail time, etc, etc.
Anonymous Poster (1); IdeaSmith (1); jack of all trades (1); PWSlack (3); Usbport (1)
