Previous in Forum: How to Control Home Incoming Electrical Power?   Next in Forum: Panel Earthing check
PAT
03/11/2013 2:06 AM
What is mean by portable appliance testing
Re: PAT
03/11/2013 4:41 AM
It's a basic safety check of the mains wiring of portable appliances (anything that is portable and plugs int oth mains).
Tests that L, N and E are connected to the correct pins of the plug earth leakage and insulation.
Re: PAT
03/11/2013 5:50 AM
One might also:
  • check the cable shows no sign of distress
  • check the plug is undamaged
  • do a continuity check between the earth pin of the plug and the case of the equipment, assuming that it is not double-insulated and not needing an earth
  • having verified the earth connection do an insulation check between live or neutral to earth
  • check that the fuse size in the plug is correct for the appliance rating and cable size (BS1363 plugs)
  • check the conductor securing screws in the plug are tight
  • check no conductors inside the plug show signs of distress
  • check the cord grip screws bear down on the outer sheath of the cable and that it is secure
  • check the plug top is secured correctly
  • make a record that it has been done
Re: PAT
03/11/2013 5:58 AM
mechanical check list for PAT
Re: PAT
03/11/2013 6:04 AM
Not applicable. PAT is electrical.
Re: PAT
03/11/2013 7:17 AM
I gave a GA, I think you also deserve a gold star for tollerance in responding to the subsequent post which didn't even have the courtesy of a question mark, never mind a 'thanks'.
Re: PAT
03/11/2013 3:12 PM
Follow your applicable local electrical codes and standards.
A PAT test (like surgery) is meaningless and dangerous if the person performing the test is not trained and qualified to do so and follows the applicable standards.
Register to Reply 6 comments
jack of all trades (1); jayashankar666 (1); PWSlack (2); user-deleted-1105 (2)
