Previous in Forum: Autocad and Solidworks   Next in Forum: Sensible Cooling And Sensible Heating
Flow Rate Through A Pipe
03/13/2013 7:50 AM
The water flowing through the pipe which is having constant diameter.As we know create pressure difference to provide flow.when we keep on increasing the inlet pressure then what is the maximum flow rate in a pipe.
Re: Flow rate through a pipe
03/13/2013 7:51 AM
Mach 1.0
Engineering Fields - Mechanical Engineering - New Member Kenya - Member - New Member
Re: Flow Rate Through A Pipe
03/13/2013 8:41 AM
Flow rate is in units of m^3/s.
The maximum possible flow rate is possible when the fluid fully fills the inner cross-sectional area of the pipe. (m^2)
Technology solves problems we didn't know existed, or didn't realise that they needed to be solved. Tinkering is therefore never pointless.
03/13/2013 8:45 AM
Practically it will be limited by the following:
  • The net positive suction head of the pressure-generating device
  • Cavitation within the pressure-generating device at the boiling temperature/pressure of the liquid
  • The pressure at the delivery end of the pressure-generating device reaching the safe working pressure rating of the pipe
  • The ability of whatever is holding the pipe secure to continue to do so.
  • The ability of whatever is downstream of the pipe to receive or to distribute whatever is coming through the pipe.
  • The ability of whatever is upstream of the pressure-generating device to continue to supply liquid.
  • The ability of whatever bends there are in the pipe to remain as bends and not straighten out with the thrust produced by change of direction at the bend.
  • Some combination of the above.
That's why Piping Designers are paid more than Plumbers.
03/13/2013 12:44 PM
Dear Friend,
Theoritically,You have to convert the Pressure in to HEAD of water in METRES. by using the Values 14.696 PSI = 34 FEET of Water Column ( 1.03 KS/CM^2 = 10.75 METRES)
From the calculated Head, you have to calculate the VELOCITY of water by using the Eqn. V^2 = 2gH, where V is the velocity, in Feet, g = acceleration due to gravity = 32.2 Ft/Sec^2, ( V = Velocity in Metre/Sec., g = acceleration due to gravity = 9.81 M/Sec^2)
You know the pipe size and Calculate the Area in Sq.Ft (or in Sq.Metres)
Then the Flow in Ft^3/ sec (or M^3/Sec.) = (0.65)xA x V
BUT THERE IS A LIMITATION FOR THE VELOCITY depending on FRICTION CO-EFFICIENT etc. Refer Hydraulics Books.
DHAYANANDHAN.S
bett4haze (1); dhayanandhan (1); PWSlack (2)
