Previous in Forum: HT Breaker Closing Time and Opening Time   Next in Forum: Cable Damage
11 comments
Steam
03/13/2013 5:44 PM
apart from power generation, what r other electrical uses of steam.
Re: steam
03/13/2013 5:57 PM
None.
Re: steam
03/13/2013 6:00 PM
The surreptitious opening of intercepted postal correspondence.
Re: steam
03/13/2013 6:02 PM
"Electrical use".
Re: steam
03/14/2013 4:46 AM
The surreptitious opening of intercepted postal correspondence e-mail?
Reply Off Topic (Score 3)
Good Answers: 44
Re: steam
03/15/2013 12:15 PM
GA
Re: steam
03/14/2013 9:15 AM
"Electrical use".
... as if Doorman reads all of the original post before responding.
Good Answers: 804
Re: Steam
03/13/2013 8:01 PM
Cleaning motors (with the proper precautions and attention to details).
Re: Steam
03/13/2013 8:39 PM
Steam can be used to initiate an electrical signal from a steam sensor....
The question is difficult to answer because the your restriction essentially cuts out most other uses with the exception being the one example you provided.
Re: Steam
03/13/2013 9:18 PM
'Steam' (water vapor) can be pumped into a room to reduce static electricity.
Good Answers: 92
Re: Steam
03/14/2013 10:36 AM
As a conducter to ease initiating an arc???
(yummy! Plasma fried hot dogs!!)
Good Answers: 44
Re: Steam
03/15/2013 12:26 PM
That's actually a somewhat arcane reference, since the steam is not actually used to create electricity in any sense any more than water or wind are. Steam turns the turbine the same as the two others. The turbine turns the generator. (These are generalities.)
You could just as easily ask "apart from power generation, what are the other electrical uses of wind?" or "apart from power generation, what are the other electrical uses of water?".
sic corrected
cuba_pete (2); Doorman (2); JNB (1); JRaef (1); lyn (2); PWSlack (1); truth is not a compromise (1); Usbport (1)
