Previous in Forum: Electrical Wiring Diagram Basics Reference Book Suggestions   Next in Forum: Capacitor duty contactors
Use of NPT Thread Cable Gland in Ex "E" Enclosure?
03/15/2013 5:41 AM
Is there any reason? why we cannot use NPT thread cable gland in Ex "e" enclosure?
I read a specs saying:
Ex "e" use metric thread cable gland
ex "d" use NPT thread cable gland
Ex "de" use metric cable gland
Re: Is there any reason? why we cannot use NPT thread cable gland in Ex "e" enclosur
03/15/2013 5:44 AM
One possibility is that the port for the Ex e enclosure already has a metric thread and an NPT thread on the gland won't fit it.
Good Answers: 69
03/15/2013 1:41 PM
That's what I understood from the text, other posibilities are that the gland connector won't fit or it will be way too loose to be tightened.
Re: Use of NPT Thread Cable Gland in Ex "E" Enclosure?
03/16/2013 3:15 AM
It will depend on the type of enclosure. If it is something like a junction box, you most likely don´t have enough material thickness (if it is an Ex"e" JB) to provide for an NPT thread, in this case some sort of parallel thhread with a washer and locknut would be used.
If it´s something like a transmitter housing, then it is just a matter of specification during ordering. All manufacturers that I know of offer the choice of either metric or NPT threads.
03/16/2013 6:39 AM
The type of gland has a bearing on the matter too. Ex d glands are marked to that effect, and designed to have a minimum of, say, 5 turns of taper thread engaged in the Ex d fitting before going tight, which is a function of the thickness of the Ex d enclosure. Ex d equipment is built like a Russian tank.
Ex e enclosures can be much thinner, in which case a parallel thread and a back-nut is appropriate; one doesn't get parallel thread in NPT though one does at, say, M20, and stuffing glands for Ex e enclosures with a back-nut can be widely used and are readily available from all sorts of suppliers. There is no such thing as an Ex e gland.
Register to Reply 4 comments
PWSlack (2); Thiele (1); Yahlasit (1)
