Previous in Forum: Capacitor duty contactors   Next in Forum: 787 Lithium Batteries
4P as Against 2P Breakers
03/15/2013 7:00 PM
Hello Sir,
We have in a situation that the input supply to our equipment only needs 2P breakers but the available breakers is 4P is it okay to use 4P even if we will use only the 2 phases we will just balance it?
Re: 4P as against 2P breakers
03/15/2013 8:02 PM
Yes. If it's an ELCB or whatever, the component datasheet should specify which contacts to use for L and N for 2 phase service. If it's just a switch, use whichever contacts are most convenient.
Re: 4P as Against 2P Breakers
03/15/2013 9:49 PM
You may also need to loop the circuit through all the poles in order to get the correct thermal response. If so, this too should be covered in the CB instructions.
03/16/2013 12:54 PM
Yes, as long as the contacts can carry the current.
Mr.Ron from South Ms.
03/16/2013 1:40 PM
Hello Sirs,
Thank you for the replies, we only need L-L so it is ok.
Register to Reply 4 comments
jhunair (1); JohnDG (1); ronseto (1); Tornado (1)
