Folks I am about to build a rectifier to convert a A C welder to DC. I want to first build a full bridge rectifier using 300amp diodes with heat sink and can. This I don't have a problem with. I want to add a inductor (choke) for which I have seen a plan to use a 6 inch long x 2 inch diameter iron core with 5 layers of 4awg magnet wire. I am having problems getting the 4awg here in the UK so could I use something else like copper heating pipe (8mm) or tri rated 22mm
What would the inductance be on the original spec in Henry's? How about using a lc circuit and what caps would be needed. 200amp at 45v is the original AC welder
