Previous in Forum: Heat Generated on a Spinning Disk Thrust Stop   Next in Forum: What is Permiability and Permitivity of Vacuum
Calculate the Radius of 300 mm PVC Pipe
03/23/2013 2:46 AM
How to calculate the radius of 300 mm PVC pipe to avoid frictional losses
Re: Mechanical Engineering
03/23/2013 9:32 AM
There is no such meaningful calculation, but a "5R" bending radius (R = 5 x 300mm = 1500mm in this example) is a common design for bent pipework.
Re: Calculate the Radius of 300 mm PVC Pipe
03/25/2013 5:07 AM
There is a table giving rules-of-thumb for friction losses of bends and other fittings in most textbooks on Chemical Engineering, among others. Try Perry, "The Chemical Engineer's Handbook", any edition, or even "Kempe's Engineer's Yearbook", any edition.
