If you look via google you will find that some of them are hydraulic rotary dampers. The fluid goes through a small gap and so the fall speed is reduced by its resistance to flow.
they may be using a viscous damping grease to keep the seat from moving fast. a small dab between the pivot bolt and the bolt clearance would be more than enough to work.
