Previous in Forum: High Pressured Gas Divertion   Next in Forum: Air Conditioning Heat Load Calculation
Calculating Wear on Shifter Pad of Gearbox
03/25/2013 11:14 AM
I have a complaint of bnormal wear of 1mm to 2mm wear on steel pad(16MnCr5) with 60hrc. Th shifter sleeve is also 60hrc steel. I am trying to calculate the force which is required to start the wear of steel pad.
There is no burning marks and is well lubricated. Theoritically the sleeve undergoes a force only in synchronization which is about 520N on sleeve considering a knob force of 70N which is measured on knob.
PLease help me calculate the force required to wear a steel pad like this under well lubricated condition. This is a conventional 5 speed gearbox layout with 4th as dricet drive and wear is only on the 3rd side and not on 4th or any other gear.
sam
Pathfinder Tags: wear calculation
Re: Calculating Wear on Shifter Pad of Gearbox
03/25/2013 11:52 AM
If this is a vehicle transmission then either the shifter is maladjusted or the operator rests his/her hand on the shifter while in operation, check the end point stops of the shifter they are probably causing a coutinuous load due to the positive stop being too tight. As far as the calculation goes I would not concern myself with that. Repair the problem and the symtoms will go away.
"Never seem more learned than the people you are with. Wear your learning like a pocket watch and keep it hidden. Do not pull it out to count the hours, but give the time when you are asked".
Good Answers: 183
03/25/2013 3:15 PM
Wear is directly related to the shear stress in the sliding zone. It is not enough to give the force all geometrical data must be available for an evaluation.
Could give more information and if possible picture of worn parts ?
The synchronization force should as well be checked if it is really in correct relation to the process (condition when commuting, dimensions and possible frictions aso).
Good Answers: 58
03/26/2013 9:02 AM
I have opened transmissions with >>200,000 miles on them and found no significant wear in that area. If you are achieving proper hydrodynamic lubrication between the moving parts, there should be zero wear. I suspect that either the lubricating oil is being wiped away during shifting and not available to maintain a film between the parts, or the transmissions are being dry shifted excessively. Perhaps to test this theory, you might want to install a small pump to force lubricate the sliding joint whenever shifting occurs.
03/29/2013 2:29 PM
Possibly the wrong lubrication? Or one that is too cheap/not a true equivalent to the recommended?
Register to Reply 4 comments
Andy Germany (1); mlindner (1); nick name (1); welderman (1)
