Previous in Forum: Hydrogenation   Next in Forum: Oblong Holes for Bolts
11 comments
Fasteners SS vs HT Carbon Steel
03/26/2013 1:08 PM
For fasteners of valves and flange joints in high pressure piping which material is preferable, Stainless Steel or HT Carbon Steel?
I feel that SS is good if not to be unfastened for long time (resistant to corrosion and whethering), but if it is to be unfastened frequently then its damage rate is much higher compared to HT Carbon Steel.
Am I right?
Re: Fasteners SS vs HT Carbon Steel
03/26/2013 1:31 PM
Not enough information.
What does the pipe carry, etc. etc?
Don't you have a specification?
Have you considered throwing darts at a board with SS ans CS targets instead of numbers? That'll be as good as any thing.
03/27/2013 1:55 PM
"Have you considered throwing darts at a board with SS ans CS targets instead of numbers?"
I check in every morning to what you have to say on a given subject...just to get my daily dose of the giggles!...Sorta like reading the comic section of the papers while on the can!
Good Answers: 183
03/26/2013 2:32 PM
Corrosion is not any more inmost cases a problem since protection caps have been already since a long time developed and are available of the shelf.
You can use SS in stead of CS ONLY if the resistance requirements are equal.
03/26/2013 4:52 PM
Use whichever is the strongest.
Mr.Ron from South Ms.
03/26/2013 11:03 PM
and depends on the flange material too. SS for SS, CS for CS (kinda sorta)
Reply Score 1 for Off Topic
03/27/2013 2:59 AM
How frequent is the dismantling?
How high is the pressure?
It would be good practice to replace the bolts regularly, if not at every use to reduce risk of shearing due to repeated stretching of the bolts.
Madness is all in the mind
Good Answers: 58
03/27/2013 7:37 AM
Details are important. If corrosion is not a consideration, then high tensile steel will outlast ss. In our lab we have eliminated the use of ss socket head bolts because they wear out too quickly. High tensile steel is only permitted, but, corrosion is not a problem.
03/27/2013 12:34 PM
I Use Both 316 L Stainless Steel and K500 Monel Coated with (Baked On) Xylan for the ease of removal in jobs where they have to be removed often.
Most of my projects are Offshore submerged in seawater.
Good Answers: 176
03/27/2013 2:13 PM
Note Rosemount's torque spec for 316 SS fasteners that is lower than the other materials, half that of carbon steel (CS), used to fasten a flanged manifold valve to the process flanges of a DP transmitter.
I'm not a materials guy, but I suspect it's lower tensile strength.
The installers tell me that they ALWAYS use anti-seize compound to allow disassembly.
03/27/2013 2:56 PM
High pressure piping typically use fasteners per ASTM A193 spec. Within this spec are both SS and carbon steel fasterners but the SS variety has a lower tensile strength compared to the carbon steel. Therefore, as others have pointed out, more info is required about your application. Have a look at Portland Bolt. They have lots of info on fastener standards. We use this resource quite often.
03/30/2013 7:17 PM
Your first concern is which codes govern the piping installation. But after that, why would want to replace HT steel with stainless? Stainless galls (making it difficult to remove), it's not as strong as steel and it's more expensive.
BGuillot (1); GM1964 (1); HeHound (1); Iris (1); lyn (1); nick name (1); ronseto (1); TerraMan (2); welderman (1); WingNut (1)
