Previous in Forum: 11kV Generator   Next in Forum: 220 Vac Supply
Unbalanced Current Standard
04/10/2013 9:27 PM
DEARS FRIENDS
COULD U HELP ME, LIMIT OF THE UNBALANCE CURRENT AND THE STANDART THAT REFERS FOR THE UNBALACE CURRENT?
THANK U
Re: UNBALANCED CURRENT STANDART
04/10/2013 11:14 PM
should be less than 9 %
04/11/2013 3:11 AM
WALOOB
04/10/2013 11:18 PM
There may not be a universal standard for this; rather, it may vary with local or regional standards.
Please turn off all-caps, which are considered shouting.
04/11/2013 3:12 AM
In the limit, the power on two of the phases is zero and the unbalance current is the same as the current in the third phase. That is what the neutral conductor does. <yawn>
Good Answers: 170
04/11/2013 3:31 AM
That depends on the type of load that is connected to the supply. Static equipment have a larger tolerance to unbalance currents whereas rotating equipment have a lesses tolerance. If you can be more specific, I can give the reference.
04/13/2013 7:52 AM
I would evaluate unbalance load at the design electrical system at my plant using etap. I want to know what the limited the unbalanced standart alert that should I input at: 1. Line voltage unbalance rate (LVUR) 2. Phase voltage unbalance 3. Negative squence Voltage unbalance rate (VUF) 4 zero sequence voltge unbalance factor ( VUF0) 5. Current unbalance ratio (IUR) 6. Negative squence branch current unbalance factor (IUF2) 7. Zero squence branch current unbalance factor What the standart value for each kind of unbalance above? Thank u
Reply Off Topic (Score 6)
Anonymous Poster (1); electricalexpert65 (1); jan63 (1); PWSlack (2); Tornado (1)
