Previous in Forum: Does Changing an Air Filter in Bike Require Rejetting?   Next in Forum: Issues Keeping Dryer in Vertical Position in a Chiller
Internal Painting Specification for Filter Housing
04/12/2013 4:34 AM
hallo...
I'm designed filter housing for diesel fuel, can any one advise me the painting specification or painting brand for internal filter Housing, housing material use seamless pipe A-106 B, will be painting with 2 layer....
thank you
Re: Internal Painting specification for filter Housing
04/12/2013 4:39 AM
Ordinarily the internals of a filter housing that is wetted with diesel don't really need painting.
What are the options?
04/12/2013 4:50 AM
the option internal filter housing shall be painting
04/12/2013 5:20 AM
Please list the options being considered.
Re: Internal Painting Specification for Filter Housing
04/13/2013 1:53 PM
"the option internal filter housing shall be painting" doesn't say much.
Either the purchaser should have specified the type of paint in the purchase order, or you should already know what to use.
Unless this is the first time this has ever been built, this should be known.
If I were buying these from you I would tell what type, and specification the paint is to be.
04/13/2013 10:21 PM
I've changed a bunch of fuel filters, gas, #1, #2 fuel oil, and do not remember any coating in any of them. The purpose of a paint(coating) is to prevent corrosion and rust. There shouldn't be anything causing corrosion in the fuel. Excess water will show up as rust, letting the operator know at change time that there is a problem.
04/14/2013 9:23 PM
dear All
thank you very much for the advice....
Register to Reply 6 comments
lyn (1); PWSlack (2); walt (1); yan warta (2)
