Previous in Forum: Reverse Power in Gas & Diesel Genset   Next in Forum: Needle Valve and Globe Valve
16 comments
Turbine
04/14/2013 4:20 PM
How does turbine work ?
Re: Turbine
04/14/2013 4:25 PM
It goes round-n-round and makes power. You can make electricity or power airplanes with them. And lots else.
Google "Turbine".
Re: Turbine
04/14/2013 4:29 PM
In accordance with the articles on the topic in Wikipedia?
Re: Turbine
04/14/2013 5:20 PM
Make one of these and blow on it; that's how a turbine works:
Re: Turbine
04/14/2013 5:27 PM
Where's the instructions, with pictures?
You also don't specify on which side to blow.
Re: Turbine
04/14/2013 5:33 PM
This isn't a homework cheat site...
Re: Turbine
04/14/2013 6:08 PM
Since you didn't specify what type of turbine, I chose a jet engine......The air is sucked in the front, compressed with a series of slanted blades, fuel is sprayed in then ignited....The compressed ignited air/fuel mixture then expands rapidly as it heats, and is forced out the rear exerting pressure against another series of blades slanted in the opposite direction driving the shaft which in turn compresses the air entering the front and so on.....
Re: Turbine
04/14/2013 6:31 PM
What keeps it from blowing back out the front of the turbine?
Re: Turbine
04/14/2013 6:44 PM
You gave away the whole secret; it really blows out between radially and tangentially. (Well, if you don't put too much curlicue in the "blades".)
Good Answers: 104
Re: Turbine
04/14/2013 7:00 PM
See 'compressor stall'.
Re: Turbine
04/14/2013 10:36 PM
Pressure waves.....? It's a delicate balance to be sure, and subject to failure with disruption in the flow dynamic....
Re: Turbine
04/14/2013 9:40 PM
it spins
Re: Turbine
04/14/2013 9:51 PM
this one works with a little water pressure and makes a couple of watts, the shaft weighs 100 tons and can be found in one of the powerhouses@the Hoover, NOT Boulder dam. they're pretty cool you should make atrip just to see them like I have
Re: Turbine
04/14/2013 9:57 PM
Let me guess: 40 poles, 180 rpm [?].
Re: Turbine
04/14/2013 9:59 PM
you're pretty smart for a column of swirling air
Good Answers: 104
Re: Turbine
04/14/2013 11:48 PM
Are they still giving tours, after 9/11? I toured one on the Tennessee River when I was a kid, but I understand they have stopped because of 'security concerns'.
Re: Turbine
04/15/2013 3:23 AM
Well, go to New Zealand instead then, because they are still happening there.
Reply to Forum Thread 16 comments
bigg (2); Fredski (3); lyn (3); PWSlack (2); SolarEagle (2); Tornado (4)
