Previous in Forum: Placement of Turning Vanes   Next in Forum: Cause of Cracks in H-13 Aluminum Die Casting Molds
10 comments
Question on Pump Gland Packing Material
04/26/2013 1:34 AM
Hi Dear Friends!
I seek your advice for a stuffing box material that is compatible for Jet fuel (petroleum product).
The pump was modified to use mechanical seal, for some sizing errors could not seal on idol position. Asbestos material was tried but it is not friendly environmentally and it also dissolve with Jet fuel.
Gashaw
Re: Question on pump gland packing material
04/26/2013 3:35 AM
The best thing to do here is to pick up the telephone, and discuss the issue with the pump manufacturers and with various seal manufacturers to see what these people can come up with. After all, they will have met the problem many times before.
04/26/2013 3:48 AM
...and solved it.
04/26/2013 5:18 AM
Stuffing boxes are generally unsuitable for flammable, toxic, or precious fluids. This is because stuffing boxes are ordinarily designed to leak at small rates such as a few drops per minute.
Good Answers: 38
04/26/2013 7:11 AM
I agree with Tornado. Any jet fuel pump should have a mechanical seal. Stuffing boxes and packing should be used on clod, non-flammable service only
Otherwise, you are just setting yourself up for a massive fire at a later date.
Was this pump used in another (non-flammable) service earlier ?
Tell us where this airport is located (so that we can avoid it in our travels)
04/27/2013 2:59 AM
I am agree with your Ans.
04/26/2013 5:32 AM
...the consequence of which is potentially a serious materials containment problem that could impact on the safety of the facility and everyone in and near it.
Make the call.
Re: Question on Pump Gland Packing Material
04/26/2013 7:38 AM
I see a new pump in your future....don't fool around with highly flammable liquids and mickey mouse patches that were never intended to be there in the 1st place
Good Answers: 25
04/27/2013 5:38 AM
May I know where are you from? My friend in Mumbai India is mfr. of all types of gaskets for various types of pumps, but it may not be feasible to supply single gasket for export.
04/27/2013 9:21 AM
If everything us up to specifications and clean with proper procedures on installation a mechanical seal should be the answer. If your personnel cannot achieve results have the manufacturing rep provide on site assistance. All packing require some leakage for lubrication and cooling so avoid this non solution for safety reasons. There are no shortage of quality mechanical seals available. Just some seem better in certain circumstances than others.
04/27/2013 5:03 PM
Hi, PTFE gland packing is one answer. I'm sure there are others, but the PTFE will do the job for most fuels and needs minimal maintentanence. Gerry D.
Register to Reply 10 comments
Fredski (1); Gerry D (1); MJCronin (1); PWSlack (3); roy hammy (1); salahsalahu (1); suresh sharma (1); Tornado (1)
