Previous in Forum: Void Detection in Molded Plastic Part   Next in Forum: Phone Calls That Make Your Day!
Formula for Pressure Testing of SS Braided Hose
04/29/2013 5:25 AM
I would like to know the formula for calculating pressure capability of SS braided hose.
Re: FORMULA FOR PRESSURE TESTING OF SS BRAIDED HOSE
04/29/2013 5:33 AM
Procedure:
1) Turn off Caps Lock
2) Carry out a force balance along a theoretical plane cut along the diameter of the tube, applying the strength of the material and a safety factor.
04/29/2013 11:42 AM
Turned off caps lock! Check!
04/29/2013 6:12 AM
The alternative is hydraulic testing of sacrificial assemblies.
04/29/2013 11:43 AM
Advised to test instead of calculating! Check!
Re: Formula for Pressure Testing of SS Braided Hose
04/29/2013 11:43 AM
What material is the hose? Check!
04/30/2013 12:37 AM
It is Stainless Steel grade 304,dia o.4mm bunched 16 *5 and braided.
05/23/2013 6:01 PM
=IF(B5>=500,B5*$C$12,IF(B5>=300,B5*$B$12,0))
I think this will work. Try it and see. If not, take two aspirin and call me in the morning.
Register to Reply 7 comments
IdeaSmith (3); lyn (1); MMMATHEW (1); PWSlack (2)
