Here is my problem, I need to simulate a 120 60 Hz AC line with various defects like harmonic distortion. The exact type and amount of the defects will likely be based on test results so I need to be able to change signals on the fly. I am aware this is not much to go on. I am driving a couple of 110 to 12 volt transformers that are lightly loaded, less then 10 watts.
I have an arbitrary waveform generator or can use LabView to generate a waveform. LabView will allow me to control the phase relative to the fixed AC reference so that may be my choice. I also have a 1KW control transformer that will produce 120 out with 480 in. I'm thinking of driving the transformer (backwards) with a sub-woofer amp and using LabView for voltage regulation since load will be fairly constant. Don't have a sub amp handy to test with but have a spare stereo amp I can bridge to mono for a test.
Workable or am I stuffed full of wild blueberry muffins (again)?
