Previous in Forum: If Power Increase What Increase First Prime Mover Power or Excitation   Next in Forum: How to Create a "Dirty" 120 VAC Signal?
Form Factor
04/30/2013 9:09 AM
Why Transmission voltages (11,33,66,110,132,220,440....etc kV)depend upon form factor i.e., 1.11 ?
Good Answers: 104
Re: Form Factor
04/30/2013 9:57 AM
if you search this forum for 'factor of 11', you will see that this subject has been discussed ad nauseum
Re: Form Factor
04/30/2013 7:10 PM
Those numbers aren't multiples of 1.11, anyway.
Nor are various other standard voltages such as 120, 208, 240, 346, 380, 480, 575, etc.
Re: Form Factor
05/01/2013 7:42 AM
But in india all are in multiples of 11kV.
Re: Form Factor
05/01/2013 11:09 AM
If you have 3-phase power, not all of them are.
Good Answers: 170
Re: Form Factor
05/13/2013 8:29 AM
It is true only with respect to AC power systems. The first known man-made source of electricity is a cell, which is DC in nature. But, after realizing the disadvantages of the DC electric equipments, AC Electricity generating machines were invented. When these AC Machines were developed, the power of these machines was to be compared with the already available DC electricity, as it is human tendency to compare anything new with the existing ones. As in the case of steam engines.
When steam engines were invented, the power of the steam engines was compared with that of the horses, which were the power sources before the invention of the steam engine.
So, a value called RMS Value for AC Electricity was derived which compared the effectiveness of the AC Electricity with that of the DC Electricity. This value is the Effective Value of AC Electricity. As we were more interested in knowing the effect of AC electricity, all measuring instruments were and are designed to measure only the RMS value of AC electricity - may it be Voltage, Current, Power, etc.
But, for the designer sitting in the design lab, more than the effective value, the average value over a period on one sinusoidal cycle of AC Electricity was important. So, he designed an AC electric Generator, which would produce, on an average, a voltage over a period of one cycle, of say, 10kV (10 is a round figure, you know).
But, when this machine was built to the design and put to operation and when the output voltage was measured, it was found to be 11kV, as the meter was measuringNOT the average value but the effective or the RMS value. This relation existed for any voltage. So, a factor was arrived at - relating the RMS value and the average value, called Form Factor, which is the ratio of RMS value to the Average value, which for a sinusoidal wave form was about 1.1. Then, when the voltage was to be transformed, it was easy to have a whole number for the turns ratio of the transformer and hence all subsequent AC voltages became multiples of 11.
bigg (1); electricalexpert65 (1); ravi142857 (1); Tornado (2)
