Previous in Forum: How To Convert Mechanical Force To Electrical Force In Generator?   Next in Forum: Fault Level in Transformer with OLTC
12 comments
Ungrounded 12,470V System - Requirements
05/02/2013 1:25 PM
I am working on a project that has a GSU transformer that is 480V delta to 12,470V ungrounded wye. This project is in the United States. NEC 250.20(c) states that systems over 1 kV shall be permitted to be grounded.
Is there a requirement to ground my medium votlage system?
Re: Ungrounded 12,470V system - Requirements
05/02/2013 1:27 PM
What does the code say? Local code, too.
What is the location?
Are you a licensed electrical contractor, licensed in the local in which you are now working????
05/02/2013 1:31 PM
Both of my codes says it is permitted to be grounded, but I could not locate anything that said it "HAD" to be grounded. I don't like that it is not grounded because of the transient overvoltages associated with it. I really want to ground it but with no code the client won't do it.
05/02/2013 1:33 PM
Then your next call should be to the local permitting/inspection agency to ask them.
Requirements vary from town to town, county to county and state to state.
05/02/2013 1:34 PM
Thanks - will do.
Good Answers: 44
05/02/2013 3:26 PM
Authority Having Jurisdiction (AHJ).
05/02/2013 5:42 PM
Thanks.
Good Answers: 131
Re: Ungrounded 12,470V System - Requirements
05/02/2013 2:04 PM
If the 12,470V will be connected to the local utility's system, they may have something to say also. Check with their protection engineer.
Good Answers: 181
05/02/2013 7:23 PM
I can't see why you have a problem with earthing the neutral point.
You don't say the size of this transformer or its intended use. A NER would be the usual option for MV but with no information it's just guess work.
This smacks of homework.
05/03/2013 10:45 AM
I can't earth the neutral point because the service is solidly grounded with induction disk relays (no directional ground fault detection) and the standby generators are grounded through a 200A impedance. The original design was to never island now they want to island.
Good Answers: 444
05/03/2013 11:43 AM
"...The original design was to never island now they want to island...", all bets are now off. This is a radical departure from the original design and requires a new complete system study, including a review of the existing system and coordination with the local utility.
This is not a simple "handbook engineering" exercise; personnel and equipment safety are at issue, as well as code compliance and insurability. Hire a competent electrical power engineer who has done this type of thing before.
05/03/2013 1:17 PM
Tell them they can't do it! Then quit.
Good Answers: 170
05/14/2013 11:40 PM
Try "ASK THE EXPERT" feature in www.igard.com"
Register to Reply 12 comments
cuba_pete (1); electricalexpert65 (1); live2learn (3); lyn (4); PeterT (1); RAMConsult (1); TonyS (1)
