Previous in Forum: Instrument I/O Type   Next in Forum: Capacitance Level Measurement
Turbine Supervisory Equipment
05/05/2013 2:22 AM
Does anyone have a step by step set up procedure for Bentley Nevada Diff Expansion probes. I've watched Instrument Tech's do it recently and I'm trying gain more information on them and how to set them up.
Thanks
Re: Turbine Supervisory equipment
05/05/2013 5:17 AM
How about asking those Techs if they can show you one or copy it for you?
They certainly will have one.
I also was able to find this.
Maybe it helps
Re: Turbine Supervisory Equipment
05/05/2013 6:03 PM
Yep. It's all in the manual. Not to hand? Simple. Pick up the phone and talk to someone at Bentley Nevada. There must be dozens of them there.
Or is that too simple?
05/13/2013 10:31 PM
I guess you don't know either , thanks all the same
05/05/2013 9:17 PM
At this point, I'd continue to rely on the professional instrument technicians to set up the instruments. Then, after you've found a way to get the education/experience/step by step set up procedure that you don't have now, maybe you can do the job.
However, having step by step instructions does not insure that you are capable of performing the procedure that a professional instrument technician uses to set up instruments.
Till then, hire a professional.
Bently Nevada Product Support - GE Measurement & Control
Register to Reply 4 comments
IdeaSmith (1); JJJ (1); lyn (1); PWSlack (1)
