Previous in Forum: Pressure Transmitter   Next in Forum: Turbine Supervisory Equipment
Instrument I/O Type
05/03/2013 7:32 PM
I am working a Instrument I/O List. What should my I/O type be for RTDs and Thermocouples?
AI-Analog Inputs - Transmitters
AO-Analog Output - Control Valves
DI-Digital Input - Switches
DO-Digital Output - Solenoids, On/OF Devices
????? - Thermocouples
????? - RTDs
Re: Instrument I/O Type
05/03/2013 7:43 PM
What do you THINK the answer is?
Can't you figure this out? Come on!!!!!
I/O List - Instrument and Control Engineering for Process Industries
This sounds like homework.
05/03/2013 9:35 PM
If you could push any numbers into an RTD, it would be a DO.
Good Answers: 176
05/03/2013 10:25 PM
Valves are chunks of machined metal with elastomer seals. How do you get a chunk of metal to respond to a AO?
05/06/2013 9:54 AM
I think someone is in the Pharma sector as my company is. it is quite common for us in this sector to refer to valves ( ball / gate ) with 4-20ma I/P positioners on them as simply a "Control Valve." Should I mention a control valve to anyone in engineering here, they will assume I mean a positionable valve with 4-20ma control. It is not uncommon to get a sketch type RFQ, from companies that don't use a big engineering firm, to have a positionable valve labeled as simply a control valve, even though they have 5 other automated valves in their P&ID sketch. (Big engineering firms tend to be more technically correct in their use of terminology.) Yes this is an incorrect label, as any valve can be considered a control valve - even manually operated ones, but it is done. His sheet looks quite a bit like one of mine. However my analog in is not limited to transmitters, and quite nicely holds the RTD's as they are definitely analog.
05/05/2013 6:08 PM
What does the "approved for construction" P&ID say about each one? Each one might be a temperature switch instrument, or it might be a temperature transmitter instrument. Only, it's a bit difficult to read the drawing from here.
Iris (1); lyn (1); Phys (1); PWSlack (1); Tornado (1)
