Previous in Forum: Machine Per Hour Rate.   Next in Forum: Hardfacing Welding Rod Without Chrome and Nickel
SA182F403L to SA965F304l
05/07/2013 9:09 PM
Hi,
I would like to know that is there any chance to change SA182F304L to SA965 F304L.
In ASME Code section II part A, SA-182 state that,
"For larger projucts and products for other applications, refer to specifications A336/ A336M and A 965/ A 965M for similar ferritic and austenitic grades, respectively, available in those specifications"
Please suggest me a way to change if possible cos we wrongly ordered for my Girth Flange material.
Re: SA182F403L to SA965F304l
05/07/2013 9:49 PM
Do you mean substitute or change one material into the other one by heat treatment or something?
To substitute you order a new batch of material and machine it the same way you have done already.
I doubt that you can change one material to the other one without big effort and smeltering it new and put it through a forge.
Basically the answer is NO.
Your last resort might be that the customer accepts the other material which has to be communicated and negotiated.
Good luck next time!
05/07/2013 9:59 PM
thanks
05/08/2013 3:46 AM
Re-order the right one, and stop wasting time here hoping and waiting.
Good Answers: 104
05/08/2013 11:31 AM
A182 is a flange, fitting, valve spec, A965 is a forging spec. Are you going to beat a flange into something else? Have you read these specs?
05/08/2013 11:45 AM
"wrongly ordered for my Girth Flange"
Maybe it's the material to be used when flanging Girths.
Good Answers: 104
05/08/2013 12:50 PM
Looks like I quit reading before the end.
06/18/2013 6:35 AM
Hi,
please have alook on handbook of comparative materials.
enlightenment is blessing and self-denial is a good recipe
Anonymous Poster (1); bigg (2); blackpanic73 (1); IdeaSmith (1); lyn (1); PWSlack (1)
