Previous in Forum: Solar Silent Assisted Power Generation - Is It Working? Vote Now.   Next in Forum: Surge Arrestor in Panels
VFD for Grinding Machine Motor
05/07/2013 10:33 PM
Dear all,
We have a grinding machine motor of 40 HP installed in the grinding machine.
The load on the machine is around 40 - 50 %.
It is used for grinding chillies into powdery form.
It is a continuous process.
I wanted to know whether a VFD would be helpful to save energy and improve efficiency of the motor and how.
Thanks in advance.
Regards,
Rooney
Re: VFD for Grinding machine motor
05/07/2013 10:50 PM
Start here: Variable-frequency drive - Wikipedia, the free encyclopedia
and then continue your research, on your own.
Or, grind a lot more chillies.
05/08/2013 3:25 AM
Here's an idea that doesn't need any investment or alteration to the equipment.
  • Load the machine up to 100% and then switch it off for 50% of the time.
Good Answers: 181
05/08/2013 8:19 AM
Is the mill capable of running at lower speeds? This could turn in to an expensive experiment if it can't.
Good Answers: 67
05/09/2013 12:56 AM
GA. It's a very important aspect while going for a change. The other aspect is the expected quality of the product- can it be mentained at same level with reduced speed.
Good Answers: 804
Re: VFD for Grinding Machine Motor
05/08/2013 10:31 AM
Not only will it NOT save any energy, it will actually More likely use MORE energy because of the losses in the VFD. Changing speed does not automatically save energy. Changing speed with a VFD can save energy COMPARED to other means of changing speed, IF changing speed is necessary for the process or task.
In your case, changing speed on a grinder just means it will accomplish less grinding, which means to grind the same amount of chiles, you will need to run longer. Since energy = power x time, you have lowered the power but increased the time, no net change.
Power used = work performed, plus any losses in performing it. So even though you have a 40HP motor, if the load is only 50% that motor is consuming only 20HP, plus losses associated with a 40HP motor, a small portion of which will be slightly greater than that of a 20HP motor. A VFD will potentially save a small portion of that small portion of motor losses, but will introduce more losses in itself and actually consume slightly MORE power to do the same work.
If your motor is NEVER loaded more than 50%, your best energy saving technique is to replace it with a new energy efficient 20HP motor. But if it OCCASIONALLY needs the extra torque of the 40HP motor, leave it alone. If it is an old inefficient motor there might be a benefit in modernizing it with a new 40HP energy efficient version, but the cost-benefit analysis must work out.
Register to Reply Good Answer (Score 12)
05/15/2013 2:18 AM
Thank you Mr J Raef...
Register to Reply 6 comments
JRaef (1); lyn (1); pritam (1); PWSlack (1); Rooney (1); TonyS (1)
