Previous in Forum: Can Someone Please Define Stem Turbine Idle Speed, Rated Speed and Minimum Governing Speed?   Next in Forum: Vessel Temp In and Out
High Gland Sealing Pressure
05/10/2013 7:19 AM
What will happen to the turbine performance & complete system if the turbine Gland Sealing Pressure goes high?
Re: Gland sealing pressure high
05/10/2013 7:28 AM
The gland will leak. As to what happens next, well, that depends upon the pressures either side of the gland and the effect the sealing fluid has on the process materials each side of the gland.
Re: High Gland Sealing Pressure
05/10/2013 8:03 AM
Eventually, system failure. That's why manufactures provide operating parameters.
05/10/2013 9:56 AM
A better question might be: "Why is the turbine Gland Sealing Pressure high?"
If you fix that problem, you won't have to worry about what happens next.
Register to Reply 3 comments
Kilowatt0 (1); kramarat (1); PWSlack (1)
