Previous in Forum: High Gland Sealing Pressure   Next in Forum: Atomizing Air Compressor
Vessel Temp In and Out
05/11/2013 9:23 AM
Dear All
Please advise anyone come across about the vessel temp, The vessel was insulate 100mm thickness what will be the temperature outside the vessel.
Regards
Re: vessel temp in and out
05/11/2013 10:01 AM
Ambient, or fairly close to it.
05/11/2013 10:05 AM
"what will be the temperature outside the vessel."
Surly you are kidding!
Sadly, you're probably not.
And you wonder why I think anonymous posters are all jerks?
Motor Contactors
Anonymous Poster #2
Re: Vessel Temp In and Out
05/11/2013 12:36 PM
This is an example of the type of post that degrades this fine website.
Typically, the question is so vague or the OP has such a limited grasp of English, all meaning is lost.
The webmaster should have a mechanism where such questions are immediately deleted and a request sent to reword the question.
05/11/2013 3:27 PM
The answer depends on the temperature inside the vessel, and the r value of the insulation, as well as the ambient temperature of the surrounding air and air movement, the distance from the vessel you are sampling, as well as the relative humidity and other factors....
05/13/2013 3:53 AM
The size and shape of the vessel relative to the structures outside it are also important factors, as are the ventilation arrangements.
New Zealand - Member - Member Australia - Member - Member
Good Answers: 43
05/13/2013 4:18 AM
What is the vessel temperature inside ??
05/13/2013 4:26 AM
And outside?
And what are the insulation material(s) and configuration?
Anonymous Poster (1); AussieBob (1); lyn (1); PWSlack (1); SolarEagle (1); Tornado (2)
