Previous in Forum: Mechanical Strength Properties   Next in Forum: Maximum RPM for Drive Belt
Use WPS (Welding Procedure) AWS D1.1 from Parent Company?.
05/17/2013 1:05 AM
Hi all,
My parent company is foreign company. It has many WPS (including PQR) in accordance with AWS D1.1 already.
Can we use these WPS for production in my company (subsidiary company)?
Thank you!
Re: Use WPS (welding procedure) AWS D1.1 from parent company.
05/17/2013 2:43 AM
Not without carrying out an acronymectomy first. TLAs are NBG.
05/17/2013 4:00 AM
I think you need to show that the new company's welding equipment and personnel can produce satisfactory welds by following the preeexisting procedures.
Re: Use WPS (Welding Procedure) AWS D1.1 from Parent Company?.
05/17/2013 10:19 PM
@PWSlack: sorry, I don't know about your comment
@Tornado: So will we write new WPS and use existing PQR for supporting (no need weld and bend test, tensile test...again)?
05/17/2013 11:17 PM
I think that in order to have any meaning, your subsidiary (I assume since you cite AWS you are located in the U.S.) should be reqistered with the AWS; you will have a book of pre-qualified welds; you will have a certified welding superintendent and you will have a welding engineer - either on staff or as a consultant.
If the parent company is registered, you should ask their welding engineer whether their membership covers the subsidiary.
05/18/2013 12:03 AM
AWS D 1.1
4.1.1.1 Qualification Responsibility.
Each manufacturer or Contractor shall conduct the tests required by this code to qualify the WPS. Properly documented WPSs qualified under the provisions of this code by a company that later has a name change due to voluntary action or consolidation with a parent company may utilize the new name on its WPS documents while maintaining the supporting PQR qualification records with the old company name.
05/18/2013 3:34 AM
Ok, I will write new WPS with the new name company (name of subsidiary company) while use old PQR with name of parent company.
Thank all
PS: any more discussion or advice is highly appreciate
Register to Reply 6 comments
Baffled (1); PWSlack (1); suvi (1); Tornado (1); tp35 (2)
