Previous in Forum: Motor Normally Operated of Rated Current   Next in Forum: Selection of Input Circuit Breaker
Differential Protection Relay
05/20/2013 12:04 AM
what is the differential protection, minimum rated transformer must be protected by diff. and where is it connected and how is it connected, advantages and disadvantages
Re: differential protection relay
05/20/2013 12:15 AM
Protective relay - Wikipedia, the free encyclopedia
It's connected into the circuit you want to protect.
Advantages are no fire.
Disadvantages? Too many to mention.
05/20/2013 2:39 AM
Here are too many materials regarding Differential Protection
Good Answers: 170
05/20/2013 6:52 AM
Depends on your local electrical codes.
Here in India, the Indian Electricity Rules, mandate differential protection for transformers of rating 10MVA and above.
Generally, transformers of 5 MVA and above are provided with differential protection.
Re: Differential Protection Relay
05/27/2013 6:43 AM
It sounds like your knowledge on protection is very limited...may be you should do a protection course first which is actually better than getting second hand information over a website.....
I can explain to you certain terms but if you dont understand protection you wont know what I am talking about....
If you are a red white and blue electrician you are very far from understanding protection....it takes a electrician about 3 to 5 years to know protection to the full extend of what it realy is
If you ask questions like differential protection, buszone protection, distance protection, short line current differential protection.......you need to know protection well.....
Register to Reply 4 comments
Anonymous Poster (1); electricalexpert65 (1); lyn (1); nobodysomebody47 (1)
