Previous in Forum: Single Phase 240 Volts to 3 Phase 240 Volts   Next in Forum: Energy Stored in Inductor
Contact Gap in VCB
05/30/2013 4:08 AM
What is the contact gap between the fixed and moving contacts in vacuum flask of VCB for different voltages like 6.6 kV and 33 kV .How the gap to be maintained in the open condition (is the gap in open condition maintained by the spring..?)
Re: Contact gap in VCB
05/30/2013 4:10 AM
Use the tool illustrated in actual use below to talk to the VCB manufacturer directly:
How about that for leadership?
Reply Score 1 for Off Topic
Re: Contact Gap in VCB
05/30/2013 3:42 PM
It depends on the construction of the VCB as it varies from manufacturer to manufacturer and can even vary between product groups. I know one company that uses magnetic fields.
More information can be found in the manufacturer's literature or through contact with the manufacturer directly, although some information may be proprietary and hence unavailable (patent protected or a trade secret).
Good Answers: 170
05/31/2013 11:39 AM
Depends upon manufacturer to manufacturer.
France - Member - New Member
06/05/2013 10:36 AM
Gap is necessary mainly to withstand impulse voltage between opened contacts.
This is highly dependant on the contact material itself, which is proprietary from one manufacturer to another.
Indeed, for a given gap , impulse voltage withstand drops significantly after the following cycle :
  • close on short circuit ,and local microweldings of the contacts.
  • open on no load ,and mechanically break the microwelds and creates spikes.
The characteristics of the spikes vary with the contact material ability to weld, and the way it behaves when breaking the welds.
By the way, this is one of the differences between a good VCB and a cheap one ...
electricalexpert65 (1); jack of all trades (1); obouill (1); PWSlack (1)
