Previous in Forum: Wireless Transmitters   Next in Forum: Differential Pressure Hand Pumps
Level Transmiter
05/30/2013 6:20 AM
How to select level transmitters on tank??
Re: Level Transmiter
05/30/2013 6:21 AM
Step 1: state the dimensions of the tank and define what is in the tank.
05/30/2013 6:39 AM
This is Heaating Medium Expansion Drum.Still now we havn't received any process data.
Can u tell me basic requirement tht we need to select type of level transmitter(GWR,RADAR).
05/30/2013 6:55 AM
  • It's not possible without some process data - the fluid(s) present, temperatures, pressures, flowrates, etc.
  • It's not possible without tank overall dimensions and shape - is it a 50ml beaker or is it 5000m3 - is it rectangular, cylindrical, spherical or some other shape - is it in the ground, on the ground or up in the air somewhere - how much headroom is avaible during assembly and afterwards - how is access to be maintained for maintenance, etc.
  • It's not possible without some idea of connections available onto the tank - flange details, screwed connections, etc.
  • It's not possible without some idea of the receiving equipment to which it is to be connected and how far it is away - 5m or 50km?
  • It's not possible without finalising a potentially explosive area zoning drawing and applying this as a selection filter.
These are the basic requirements!
Re: Level Transmitter
05/30/2013 7:36 AM
If you have to ask and you don't understand what must be known to select a level sensor then by definition you are not qualified. Hire somebody before you kill somebody.
Register to Reply 4 comments
prameela_kumari (1); PWSlack (2); redfred (1)
